Hi, as in my other thread if i cant get hold of "non" foglight GTI honey comb grills, i will opt for the foglight grills.
a few questions about them..
1. where would i find the new switch for them, is it a straight connect and swap?
2. i see a number of cars driving around with all 4 headlights on (the bottom ones in place of the fog lights, but not being used as foglights)?
How would i be able to do that?
Or do they light upon turning on the headlights but only become very bright when the fog lights are turned on?
3. i remember some one telling me the fog light wiring is all ready in the car, where would i find it?
4. What bulbs to use?
Thanks Lewis.
Any help would be appreciative!
Fog lights..
Re: Fog lights..
Switch can be picked up new from a dealer, or a scrapyard. Polos, Golf Mk4s, Boras of the same era all have the same switch
Not sure what you mean on number 2 - fogs and headlights on together? if so, this can be done as standard.
3 - yes it is. its connected to a blank connector either side of the inside of the bumper area
4- fogs use H7 bulbs same as your headlights.
Re: Fog lights..
like this (example)
the bottoms arnt being used as fogs, but standard lights.
thanks for the other answers!
Re: Fog lights..
Id say the bottoms are being used as fogs lol - fogs and headlights can be run together like that on polos too.
Re: Fog lights..
lol, ok.
but running fogs and headlights with out it being foggy, im pretty sure thats illegal becuase there very bright?
im only asking because i see lots of cars on the roads that have all 4 lights on when its not even foggy.
and im sure they dont turn there fog lights on for the fun of it?
thanks for the answers tho!
Re: Fog lights..
It is illegal, but most dont worry.
Now what you say is interesting. You can get LEDs to replace the fogs which are pretty kl - i have that, or you could poss wire in a big resistor to drop the voltage and dim the bulbs perhaps?
Alot do for the fun of it beleive it or not!
Re: Fog lights..
haha! So if i install the fogs with LED lights.
Could i only run the front head lights and LED 'fogs' with out the rear fog light being on?
Re: Fog lights..
Indeed
Re: Fog lights..
I got my replacement fog switch from here for £13
http://www.veedubmachine.co.uk/index.ph ... cts_id=338
