Boot Bulb
BobbyG
Boot Bulb
Post by BobbyG »
Anyone know what bulb is used in the boot light?
Tim_GTi
Post Whore
Re: Boot Bulb
Post by Tim_GTi »
Pop it open and have a ganders! Really easy to access (I'm in uni so can't check my own)
tegwin
Re: Boot Bulb
Post by tegwin »
Thats assuming you have the light fitting in the boot?
My polo for some reason doesnt appear to have ever had a light in the boot... the cables are there behind the pannel... but no holder... most odd!
BobbyG
Re: Boot Bulb
Post by BobbyG »
That is indeed most odd!
emma_88
Drives: 6N2 Polo GTi & 9N3 Polo GTi
Re: Boot Bulb
Post by emma_88 »
tegwin wrote:Thats assuming you have the light fitting in the boot?
That's exactly what mine is like!! Very annoying indeed.
Tim_GTi
Post Whore
Re: Boot Bulb
Post by Tim_GTi »
Yeh, mine was all there. But the wires weren't connected up, they were tucked away :?
kingsleysaywell
Re: Boot Bulb
Post by kingsleysaywell »
Where is this boot light mean to be ?
Tim_GTi
Post Whore
Re: Boot Bulb
Post by Tim_GTi »
kingsleysaywell wrote:Where is this boot light mean to be ?
Left hand side underneath the plastic shelf.
BobbyG
Re: Boot Bulb
Post by BobbyG »
Took the bulb out this evening, it's a C5W for future reference!
The filament looks to be intact, which leads me to the possibility of this being a wiring problem! (very unlike my car to have wiring problems!! :roll: )
alexperkins
Site Admin
Re: Boot Bulb
Post by alexperkins »
Its probably not wiring - its most likely to be a fault in the lock microswitch as these fail all the time (this controls the boot light, and the open boot light on the dash)
Tim_GTi
Post Whore
Re: Boot Bulb
Post by Tim_GTi »
Or it's not wired up properly, as this has been a popular issue with the 6N2.
There's a plug socket that joins wires further down the line (under the rear passenger seat carpet normally IIRC) that has often been found to not be connected up properly.
BobbyG
Re: Boot Bulb
Post by BobbyG »
I can't say I've ever seen a "boot open" indicator on the dash, although I'm not sure I've ever been sat in the driving seat whilst the boot is open! Where am I likely to find the boot lock microswitch?
I'll also check the wiring as per Tim's comment.
