iPod adapter
alexperkins
Site Admin
Re: iPod adapter
Post by alexperkins »
its not getting power then. Hmm. Is it firmly plugged into the adapter wire (wire from the HU to the adapter box)? It check your ground connector is solid - it could be a problem with that. Have you got a multimeter?
Gillen
Re: iPod adapter
Post by Gillen »
Ok so its now powering up ie when i put the ipod in to the adapter the ipod lights up. However, the main menu of the ipod comes up but then 1 second later it changes to a screen saying "OK to disconnect" then instantly flicks back to the main menu and carries on doing this!
alexperkins
Site Admin
Re: iPod adapter
Hmm try doing a reset on your ipod before plugging it in. Press and hold menu and the center button until you see the apple logo then plug it back in ;)
Gillen
Re: iPod adapter
Post by Gillen »
Already tried it and made sure i have the most up to date firmware on the iPod. It's the iPod Video 30GB and its a 5th generation one, which is compatible with this kit.
alexperkins
Site Admin
Re: iPod adapter
I have the 60GB of that gen, and when I had my VW iPod kit it worked fine. It sounds like a power problem still. You dont by any chance have another iPod or HU to try it against do you? There has been a known fault with certain batches of the iPod kit not working properly after a certain period.
Was it new or used?
Gillen
Re: iPod adapter
Post by Gillen »
Used :(
Only other thing i have is an iPhone which doesn't fit in the adapter. Don't know anyone else with a Polo
alexperkins
Site Admin
Re: iPod adapter
iPhone doesnt fit?! surely it should as they use the same connector?
Hmm try unplugging the quadlock on the back of the radio and check the ground again. Something isnt connecting right somewhere (well thats the card I think its wise to play at this point anyhow!)
Gillen
Re: iPod adapter
Post by Gillen »
Yeah it doesn't fit in to the cradle i've got for it.
Will check all the connections again tomorrow :roll:
alexperkins
Site Admin
Re: iPod adapter
Oh its a cradle I see. Can you remove the cable from the cradle at all?
Gillen
Re: iPod adapter
Post by Gillen »
Yeah you can, however there is no casing around the part that actually plugs in to the bottom of the ipod when you unplug it from the cradle. I suppose this doesn't really matter if i take it out of the cradle and plug it in to my iphone and see what happens!
Gillen
Re: iPod adapter
Post by Gillen »
Ok so it works with the iphone, but i the iphone doesn't fit in the cradle, which is s**t.
M4T VW
Re: iPod adapter
Post by M4T VW »
Looks to me like the illumination plug which is normally a brown wire pre can-bus.
My Lupo had one going to the in dash CD changer.
alexperkins
Site Admin
Re: iPod adapter
Hmmm thats very odd. It would suggest an iPod problem if it works with the iPhone. What about plugged into the ipod when its not in the cradle?
Gillen
Re: iPod adapter
Post by Gillen »
Yeah I tried it with the iPod when not in the dock, same thing :(. Must be a problem with the iPod :( got the most up to date firmware on it and tried resetting it a couple of times. The iPod works in my Onkyo dock for my hifi!
alexperkins
Site Admin
Re: iPod adapter
try a full restore on iTunes - that might do it ;)
