Hi, I found a set of leather and heated Golf mk3 GTI seats and are at a very good price. Would they fit in a 6n2 polo? maybe changing the rails? and btw will I be able to make the heating work or you need other staff (apart from the switches of course)??
http://www.maltapark.com/item.asp?ItemID=627844
Changing front seats??
- Gary Gee
Re: Changing front seats??
u need the heated seat looms...
and u dont need to change the rails they are the same (i have cream leather in mine) the back need to be modified for them to fit but other than that its a perfect fit..
its simply take the plastic bits at the back enf our rails out ( screwed i think) and then undo the bolt on the front ( on the adjuster bit) and then slide it out the back
Simples !
Simples !
tks very much mate
. actually I was only planning to change the fronts. but just in case I buy the back seats as well, what modifications are involved? I think the golf seats are much wider than the polo's
- Gary Gee
theres a guide some where but u have to change the cushion bit off the golf ones and on to the back of ur polo ones... some one will know where the guide is for u
