I'm after the following bits so if anything takes your fancy i'm quite happy to swap http://www.uk-polos.net/view ... 12&t=47821
6N2 GTi Climatronic system facia and outer trim for the Polo, the condition is like brand new and includes the facia surround. Looking for £20 + postage for this.
VW OEM 6 CD Changer + loom for sale. Unfortuantly the loom is spliced into two so that the unit can fit a prewired example. For plug and play you would need to buy one on ebay for £10ish. Working when last used. Looking for £45 +postage or can be collected. Also comes with both the brackets and the bolts to hold it in.
6N2 GTi Engine cover Usual 1.6 16v letters, immaculate condition and comes with the bolts required to fit. Looks good and finishes off the underbonnet very well. £35 +postage
6N2 Rear Lights. Set of very good conditioned (freshly polished & waxed), includes bulbholders and the bulbs to go in. This would be a perfect replacement for a set of worn or damaged 6n2 lights or if you want to convert your 6n's rear lights. See the guide on how to do it over on UK-Polos. £45 posted
Rear window heater switch for the 6N2, very good condition (like new). £5 posted
Hazard switch for the 6n2, again good condition and working £5 posted
VW Polo 6N2 GTi interior Light with Bulb. This is the blueish type lense casing, not the hazy amber like the 6n. £7 + posted
VW Polo 6N2 Above heating dash slot Usual slot the 6n2 has above the heating control, good condition and clean. Only want £4 posted
VW Polo 6N/6N2 Door handles blanks, i've got a pair of these from the rear of a 6n so ideal for delocking your passengers side or replacing a current one. In black plastic. £10 +postage for the pair.
VW Polo 6N parcel shelf In very good condition, only want £10 for it, offer me something for it as its just sitting around!
