Mk5 Polo rear wiper upgrade
Parin
Post by Parin »
Hey guys I'm upgrading my front wipers soon so i thought i might aswell upgrade the rear one to an aero one, i wanna upgrade it to like the new vw's,
seen somethin about a 9n or a passat rear wiper?
anyone kind enough to point me in the right direction?
cheers Parin
Mart!n-GTI-DK
Drives: '14 Polo BlueGT
Re: Mk5 Polo rear wiper upgrade
Post by Mart!n-GTI-DK »
The rear wiper from the New Scirroco fits it perfectly...
I have put it on mine.
Bradley
Post by Bradley »
Hey dude,to upgrade to the newer type Aero wiper these are the parts & part numbers you will need.
The wiper arm: 6q6 955 707 c
The small button type cap for the arm: 6q6 955 435 b
The wiper blade: 3c9 955 425
Hope this helps.
alexperkins
Site Admin
Post by alexperkins »
that looks like what i typed a few months back :P
Si_GTi
Moderator
Post by Si_GTi »
Does the Scirocco wiper blade fit without needing to be adjusted (alexperkins knows what I mean) or is it a direct "bolt-on" job? I need a new rear blade (I have had this upgrade installed since 2008) and if I can get one that doesn't need messing with, then all the better :lol:
Mart!n-GTI-DK
Si_GTi wrote:Does the Scirocco wiper blade fit without needing to be adjusted (alexperkins knows what I mean) or is it a direct "bolt-on" job? I need a new rear blade (I have had this upgrade installed since 2008) and if I can get one that doesn't need messing with, then all the better :lol:
It's a simple bolt on job :)
alexperkins
Site Admin
:P indeed!
It should just be a new blade - they all appear to use the same arm...let me look on etka for the part number
Bradley
Post by Bradley »
Yeh the part numbrs were the same alex,i copy the part numbers down of things i think i may need or pop up often.Not trying to take your credit or anything :oops:
alexperkins
Site Admin
haha thats cool :P
Good idea mate! its good to keep a list :)
emma_88
Drives: 6N2 Polo GTi & 9N3 Polo GTi
Post by emma_88 »
I've done the same Brad lol. It's handy to have part no's at hand.
Anywho, just to confirm, are those part numbers for the Scirocco rear wiper???
alexperkins
Site Admin
Those parts are for the passat rear wiper. The arm and cap are the same, Ill post the part number up for the blade tomorrow when im at my workshop :)
alexperkins
Site Admin
Martin - is the scirrocco wiper as big as the original polo one. ETKA says its 255mm whereas the Polo one is 280mm
Mart!n-GTI-DK
alexperkins wrote:Martin - is the scirrocco wiper as big as the original polo one. ETKA says its 255mm whereas the Polo one is 280mm
The "wiping area" is 7-8 mm shorter on either side... But you really don't notice it...
I went down to my local VW dealer with a measuring tape and went around the lot to physicaly see if any of them aould fit my Polo.
alexperkins
Site Admin
Ah i see. That would work out then :P
I think ill stick to the passat estate wiper and just move the clip lol!
