Rclick Window Rollup installation
lowfoon
Post by lowfoon »
Anyone know how to install this for the Rclick RCL unit??
jacko7165
Re: Rclick Window Rollup installation
Post by jacko7165 »
if you have total closure off the key then you will need to purchase a 4 pin relay to hook that up
when you have a relay connect it as follows
pins 86 & 87 of the relay connect to 12v+(this can be taken from the red/white at the pump
connect the green wire from your r click kit to pin 85 of the relay
connect pin 30 of the relay to the grey/red lock wire at the pump
alexperkins
Site Admin
Post by alexperkins »
ill add that to the guide if thats kl jacko ;)
jacko7165
Post by jacko7165 »
yes mate :D
lowfoon
Post by lowfoon »
jacko7165 wrote:if you have total closure off the key then you will need to purchase a 4 pin relay to hook that up
So just adding a relay works the windows? Is there nothing to connect up the the window wiring?
alexperkins
Site Admin
The car is prewired for it as it already has the feature on turning and holding the key - you are merely tapping into the wiring
lowfoon
Post by lowfoon »
O yeh I remember - how do you use that feature again??
Would this relay be ok?
http://cgi.ebay.co.uk/Guardian-24V-22-A ... 2559692032
alexperkins
Site Admin
As said, turn the key in the drivers lock and hold it and itll either put windows up or down.
http://www.maplin.co.uk/Module.aspx?ModuleNo=37526 N00AW 30A SPDT That one
The one you linked to is a 24V, and as cars are 12V, it will not work.
lowfoon
Post by lowfoon »
alexperkins wrote:As said, turn the key in the drivers lock and hold it and itll either put windows up or down.
Thanks dude! I'll pick one up tomo
jacko7165
Post by jacko7165 »
you will also need some Wire Connectors to hook up your relay
lowfoon
Post by lowfoon »
Cheerz dude
lowfoon
Post by lowfoon »
OK, have connected all pins but I have several issues
Instead of grey/red I have white/yellow but I have determined it is the lock wire.
The car opens fine but when it locks I get 6 'bong' sounds from the front of the car and several dashboard lights on but faded. Also the windows do not roll-up :?
When I remove pin 85 which is connected to the green wire of the Rclick unit, the central locking works as normal but still does not roll-up windows
Any help appreciated!
alexperkins
Site Admin
Hmm that doesnt sound right at all. Ill check the wiring schematic....
lowfoon
Post by lowfoon »
alexperkins wrote:Hmm that doesnt sound right at all. Ill check the wiring schematic....
What do you mean by wiring schematic?
Also does yours make a single 'bong' sound when opening or locking you car?
And what does the green wire supposed to do?
alexperkins
Site Admin
wiring diagram mate thats what it means
On further investigation into this, the electric window rollup is controlled by a trigger from the CL pump to the convenience system control unit, which is linked to the electric windows, and this tells them to go up.
It would be wise to remove the relay, and not use the rollup feature, as its not designed to work on this car im afraid. Just checked the rclick manual, and it definately wont work :(
