Ricky's Green 6n2 - SOLD....BMW POWER
RS_GT
Re: My Green 6n2 + UPDATES!!
Post by RS_GT »
dub6n2 wrote:plug the cable, switch the ignition and then from the options check that you have the working COM Port chosen by running the test. if it is giving you that error either the ignition is not switched on or the wrong port is chosen. and preferably always choose the same USB port or else you will have to continually change the COM port setting
cheers matey, i think i was being a plum and didn't have the ignition switched on. il have a go during the day.
thanks for the help :)
alexperkins
Site Admin
Post by alexperkins »
Also change start KBAUD to 9600 - it will cause errors otherwise
Id get a new brake light switch from the dealer. They revised the part since making the Polos due to the fact its very prone to failing.
dub6n2
Post by dub6n2 »
alexperkins wrote:Also change start KBAUD to 9600 - it will cause errors otherwise
where do you change the KBAUD from? doesn't seem listed in the options
RS_GT
Post by RS_GT »
i didnt see KBAUD but 'Start BAUD' is there under the options part where you test your ports, is that the one you mean alex?
RS_GT
Post by RS_GT »
turns out the brake light fuse was blown, alls good now but i still have EPC and engine check on the dash gonna see what vagcom can pick up
RS_GT
Post by RS_GT »
Postie should be dropping off my rear spoiler tomorrow and am going to pick up my splitter tomorrow too, body mods are almost finished. next job....coilies! :D
skooby99
Post by skooby99 »
what kind of splitter are you going for
RS_GT
Post by RS_GT »
skooby99 wrote:what kind of splitter are you going for
Tust a regular gti one, but im going to keep it black. i havent seen another one that i really like, except thers that reiger one on that silver 6n2 with 17s on, cant remember whos it was. but dont think that would suit my car
skooby99
Post by skooby99 »
where you managin to source the splitter from if you dont mind me asking
RS_GT
Post by RS_GT »
skooby99 wrote:where you managin to source the splitter from if you dont mind me asking
i just went to my local TPS (trade part specialists) which is next door to my local VW showroom but im sure you can order one at an actual VW showroom. or have a look on here for your local TPS
http://www.thetradepartsspecialists.co.uk/
splitter was roughly £50
alexperkins
Site Admin
RS_GT wrote:i didnt see KBAUD but 'Start BAUD' is there under the options part where you test your ports, is that the one you mean alex?
Thats the one!
RS_GT
Post by RS_GT »
got a few goodies today :D
after some HARD work, blisters and scrapes later, managed to get the splitter on and the bumper grille is finally changed
very happy with how it looks now, the splitter is beefier than i thought it would be :D
also changed one of the window winders, and the mechanism that holds the indicator light in, because the black bit snapped of and the light kept popping out on bumpy roads...only to find my other one was broken too, so will need to get another kit maybe next week
will maybe start preppin the spoiler today too
RS_GT
Post by RS_GT »
spent yesterday sanding down the spoiler as it was a bit messy to start with and then got all primered
got home from work today, gave it a quick sand down with some 1200 and got it all smooth and also managed to get some paint on it :)
6N2 GTI 00
Post by 6N2 GTI 00 »
Looks good mate, the GTI front splitter really does make a big difference along with the honeycombe grill's.
What you got planned next then?
RS_GT
Post by RS_GT »
6N2 GTI 00 wrote:Looks good mate, the GTI front splitter really does make a big difference along with the honeycombe grill's.
after the spoiler i think that will be it with the bodywork, i want to get some wind deflectors though
then i will drop it hopefully in June as i have exams in May. i like the look of the Eibach sportline springs on MBoyle4's gti, if not i might pick up a set of JOM coilovers
but before that it will just be the small details and some engine maintenance but il see how it all goes :D
