you will need Trox drivers, screwdrivers, alan keys and a socket set. cutting equipment ( i used a angle grinder)
1. remove the front bumper to do this you must remove the grill (2 torx) then the under tray and the arch lining screw that are attached to the bumper and two screws behind lower grills
2. remove the light over the intercooler
3. undo the boost pipes on the bootem metal pipe and the pipe on the plastic pipe on the top
4. remove intercooler (3bolts)
5. remove sensor in the top of the intercooler and put it into the new pipe supllied in the kit with the supplied screws n reducer
6. remove front crash bar and either cut holes n drill holes in ur crash bar or make do with the seat one (if u do this the horn has to be relocated difficult if u have fog lights.)
(bit different to the location of it normal)
7.fit cooler to crash bar with the two long silacone pipes
8. cut holes that are required on the front of the plastic part that holds the rad and lights on enough so the holes on the crash bar line up with the threads on the car (this is about an inch or two)
9. put the crash bar on with cooler attached
10. atach pipe work required and secure
11.cut bottom grill on bumber to allow intercooler to fit.
i know it not that gd but ask me any questions you like. it is my first but i can improve as needed, i also used the forge guide so using this with that u shouldnt have many problems
hope its ok
