Is my climatronic broken?
chris meardon
Post by chris meardon »
So I have 9n3 GTI with climate control climatronic,
When i Stick it to low and with econ on its still not cold!!! Is this actually air conditioning? I had the same problem in the 6n2 with climatronic and assumed the new one would be different. I cant get freezing cold air out!
Any advise
K.I.T.T.
Drives: Bicycle
Re: Is my climatronic broken?
Post by K.I.T.T. »
Tried it with econ off?
Ash
chris meardon
Yup
No noticable difference between the 2 to be honest.
monk
Post by monk »
try refueling your freon.
econ = aircon off
chris meardon
Re fueling my freon? Is that just aircon?
blazeguarder
Post by blazeguarder »
chris meardon wrote:Re fueling my freon? Is that just aircon?
Its the gas in the air con. Thought they stopped using freon though? Something about kids getting high off it? May be wrong though...
You can get it tested for leaks at the same time as it's refilled. Think Kwik-Fit do it IIRC.
monk
Post by monk »
all the aircons are based on freon from what i know.
blazeguarder
Ah, my mistake... :oops:
monk wrote:all the aircons are based on freon from what i know.
Steady there, no one is allowed to use Freon nowadays - mind you it used to be very useful for cleaning components etc, but it also got a bad name for causing depletion of the ozone layer in the upper atmosphere. The cruel thing is that the old "Freons" or CFCs are more energy efficent that the HFC etc replacements. All cars from about 1988 onwards get loaded with R134 which is not as "bad" a fridge gas as R12.
Montreal Protocol and F Gas regs have tightened up what is used and how its use is controlled.
But as said, econ = compressor running on bypass with econ off the compressor should start working on the R134 and moving it in a compressed state around the system, maybe just needs a top-up as these systems loss 10grams through the plastic/rubber piping per year - plus more from any actual leaks.
monk
Post by monk »
hmmmm... this is odd. in romania all the auto dealers top up the aircon with freon. maybe they just use the term freon but in stead its something else.
