[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 bike carbs for 1.0mpi??? - UK-POLOS.NET - THE VW Polo Forum
is it a very expensive mod to do for this type of engine? does it consume much more fuel and it would be great to hear some feedback from someone who have already done it what carbs are best for the polo?
I found this list for some of the parts you would need and their estimate prices (here the manifold is mentioned twice and the carbs can be bought for less):
Inlet manifold £176.25
Overhaul customers carbs £78.75
Manifold and R1 carbs £320
Facet fuel pump and Filter King regulator £69
Universal choke cable kit £12
Throttle cable kit £10
I heard that I makes quite a good difference especially on small engines, not sure though. Yeah most probably the pedal box will have to be changed with a 6n if they are cable operated. It is still just a very vague idea...just collecting ideas and opinions. I thought of this idea cos they really look great and sound especially awesome
Why wouldn't you keep the box though? Wouldn't it be cooler to strip down the throttle body and use the actuator and bits to operate the carbs? The positions will still be the same?
Adam- wrote:Why wouldn't you keep the box though? Wouldn't it be cooler to strip down the throttle body and use the actuator and bits to operate the carbs? The positions will still be the same?
Although, response might not be as good.
the drive by wire is one of the things I hate most in my car as it seems sluggish and suffers from a slight lag at fast throttle from idle. So I would be more than happy to get rid of it if it was the case
yeah I wasn't too sure either about the nifty performance gain I will get. I will save up for a TDI one day and tune that one hehe thanks for the opinions though mate
as for the management you will have to remove everything attached to the standard intake manifold and therefore even the standard injectors. you have to buy a new fuel management system for the new carbs and their fuel jets. It is quite expensive but said to be much cheaper than individual throttle bodies or a set of webers. I have got a pdf file that explains everything about them, maybe some time I uploaded for you
but then if your having a 6n pedal box are they cable clutches i'm not that sure but in the 6n2 there hydraulic aren't they so that would be a ball ache
Could you not just leave the injectors still in place and just take off the fuel lines.
Then the car thinks it's fuelling correctly, and the carbs do they're own thing? You'd just have to get them tuned properly..
Upload the PDF mate, I'm curious about what it says.
Cause it would be a fortune to then run standalone management too..
nick6n2 wrote:but then if your having a 6n pedal box are they cable clutches i'm not that sure but in the 6n2 there hydraulic aren't they so that would be a ball ache
nick
nah my clutch on the 1.0mpi doesn't seem to be hydraulic mate not sure about other models though
Adam- wrote:Could you not just leave the injectors still in place and just take off the fuel lines.
nah you can't just leave the injectors there cos they are attached to the inlet manifold and that has to be removed. in that pdf you have an estimate of the costs (though in the pdf they were to be fitted on a nova)
