Its not a switch...its a temperature sensor for the aircon. If you have aircon, you have a sensor.
PM me your chassis number (WVWZZZetc) and ill check the parts.
Airco issues
Re: Airco issues
Ok, update on this one:
- Bought the sensor switch and the pollen filter, fitted this morning. No difference
Went to Kwik Fit to get the system re-gassed (was already done in October last year). System said - no gas in system. Re-gassed now for £49 and all working, not sure how long for of course.
The system also said there was no leak ...
So ... why did it work in October when I took delivery of the car after they "fixed" it as it was not working on the test drive, and a few months later it stops working even though the system says - no leak.
Re: Airco issues
All good in the end
Sensor couldve been contributing!
Re: Airco issues
My concern is that if it was re-gassed in October, and now having 0 content, what is there to say that it won't be empty in a couple of months again ...
Re: Airco issues
Itll be under a 'warranty' as such.
You must have a leak somewhere
It can leak from the bottom of the aircon pump, or from the condenser unit in front of the radiator in the front bumper - thats the most likely area. Mine had a small leak that had to be addressed there.
