clunking sound over uneven road?
benmkiv
Post by benmkiv »
ive been told it may be the top moutns for the susp,
its not coilys but i believe its sitting on 40mm springs, any advice or know how?
Gary Gee
Re: clunking sound over uneven road?
Post by Gary Gee »
Or could be popped shocker...
Bounce each corner and see If ones squishyer than the others
Adam-
Post by Adam- »
Springs moving around (or lifting off the mounts) when they encounter an uneven surface?
Like, they lift out their mounts for a second as the car raises, then fall back into place?
benmkiv
Post by benmkiv »
not a top mount, checked those yesterday dont thuink its popped shocker either also checked that, they all seemed pretty solid.
i think its jst the fact its running on springs.
i think turn up the music louder i cant hear it :)
RS_GT
Post by RS_GT »
benmkiv wrote:not a top mount, checked those yesterday dont thuink its popped shocker either also checked that, they all seemed pretty solid.
i have coilies on and they were clunking due to the top bolts not being tight on the back
also when you jack the car up, can you move the springs around at all?
Adam-
Post by Adam- »
He said he's on springs, so i don't think that's an issue? Unless the springs are too short and bouncing out their mounts like i said?
How d'you stop the springs falling out when you jack the car? The guy never sent me the helper springs (I'm assuming that's what they're used to do?!)
RS_GT
Post by RS_GT »
Adam- wrote:He said he's on springs, so i don't think that's an issue? Unless the springs are too short and bouncing out their mounts like i said?
Im sure the top mounts still got to be tight regardless of what suspension he has, maybe when the springs were fitted it wasnt tightened properly
theres not much you can do if the springs fall out,just means your springs are too short for the shocks. im sure helpers are only for coilovers though :?
