How to check gearbox oil level?
pocketrocket786
Post by pocketrocket786 »
can someone please advise on how I would check my gearbox oil - ie: where I should be looking to locate it under the bonnet.
Also how do I change the gearbox oil myself?
thanks
alexperkins
Site Admin
Re: How to check gearbox oil level?
Post by alexperkins »
you need to take out the fill plug on the front of the gearbox facing the bumper and stick your little finger inside. The oil should be level with the bottom of the drain plug opening
It wont drop unless you have a leak tbf!
tegwin
Post by tegwin »
Mr Alex....... Do you know what oil should ACTUALLY go in the GTI gearbox? Want to re-fill mine before the alps trip... but cant figure out what I need....
alexperkins
Site Admin
75W90
If you want to do it properly, get it from VW as its a fully synthetic blend ;)
tegwin
Post by tegwin »
You recon the VW stuff is better than some of the castrol stuff? I guess at the end of the day... oil is oil.... lol
alexperkins
Site Admin
Aye. Gearbox oil is a little different to normal oil though, as its a 'fill for life'. Its got a special polymer blend in to prevent wear. I swear by it!
tegwin
Post by tegwin »
hmm... ook then... il give that a go... had some castrol stuff in there for the last few years... but I think it wants a change!
Will go speak to the VW guys later... I need a new drain plug because I suspect mine is going to get mullered taking it off!
alexperkins
Site Admin
TPS mate dont forget ;)
6N2 GTI 00
Post by 6N2 GTI 00 »
alexperkins wrote:75W90
Nice one :D I have been meaning to get some too.
Cheers Alex
big896
Post by big896 »
just looking at what people are saying about the gearbox on the gti's and found this bit, dont use any other oil other than the one your man said from vw as it is a diffrent blend and anythink elce would cause wear quicker! all i have evea put in mine is that and im on 104,000 miles same box so... cheers!
alexperkins
Site Admin
happy days mate :)
