Vag Com Windows 7
d_austin974
Vag Com Windows 7
Post by d_austin974 »
Hi guys, i have just bought the obd2 cabble off ebay but when i plugit into the USP port the computer says it has not been recognised and it has malfunctioned. The readme i got with the cable says it is compatible with windows 7 but it only gives instructions for how to install the driver on older versions of windows. Can anyone help me out?
alexperkins
Site Admin
Re: Vag Com Windows 7
Post by alexperkins »
download vcds lite
http://www.ross-tech.com/vcds-lite/download/index.html
this will work on 7. vagcom will not
Drivers for the lead are here
http://www.ftdichip.com/Drivers/CDM/CDM ... tified.zip
d_austin974
cheers alex i'll give that a go
d_austin974
hi alex. how do i actually install the drivers for the cable. I have tried going through the troubleshoot option and update driver, but my computer just says the driver is up to date. havw you got any ideas?
alexperkins
Site Admin
you need to specify the location, and choose where you have extracted the driver zip to :)
d_austin974
I tried that and it says the driver is up to date.
But when i check the driver details it tells me that there isnt one installed?
alexperkins
Site Admin
hmm have you tried restarting. Also, try a different USB port.
d_austin974
yea dude tried all that, i have contacted the ebay seller but no reply yet. I'll stick at it n let you know if i get anywhere. Thanks for your help and if you think of anything else give me a shout.
d_austin974
i've just had another quick thought. Does it matter that mine's the 64bit version of windows 7. Are the drivers you posted above the correct ones for this version? thanks again
alexperkins
Site Admin
no and yes. I have 64 bit windows 7 and I have no problems with it.
Can you screenshot the error you are having and post it up?
d_austin974
thought i had a breakthrough for a minute there. managed to get the driver installed but now its a new error message saying that the device cannot be started. im taking a few screenshots now.
d_austin974
so i plug in the lead and this bubble appears
so i troubleshoot the device and there are its properties
you can see here it says no driver is installed
so i install the driver, i get this warning and go ahead with the installation
so once i install the driver i get this error message
Do you know what i'm doing wrong?
alexperkins
Site Admin
Try a different computer and see if the error persists. If it does, then its a faulty lead
d_austin974
will do alex, thanks for all your help. I'll let ya know if i get it sorted out!
