Need help with juddering! Possible mis fire?
Hey guys and gals!
I went through a puddle a few weeks ago and then when I put my foot down the car juddered on accelerations. After a few days the juddering stopped. I havnt noticed the problem again until recently when driving in heavy rain the car started to judder again. Almost like a misfire. This happens in all gears but really mainly noticeable in higher revs! I'm not sure what it can be as it's a few days later and the problem continues. Ive had ht leads changed a few months ago when the car had a mis fire then. Could it be a sensor or maybe dirty air filter not getting enough air though? It's a 1.4 8v hope you guys can help!
Thanks Joe
Thanks Joe
Re: Need help with juddering! Possible mis fire?
get it plugged in to vagcom thatll solve the mystery
Cheers fella! Any chance that an aa mechanic would have access to that?
hmm possibly
Nothing to loose aye :p I'll let you know the verdict! Wasn't there a link to like a free vag com programme for your pc or am I dreaming?
yes, but you need the lead
cheers alex, i might look into that in the future!
I've just got out the aa mechanic who suspects a faulty / breaking down coil pack. he didnt have any diagnostic tools with him but ive done a bit of research and it does seem that it is suspect.
i phoned my garage who said it might be around £90! is that about right?
It could well be the coilpack actually. Thats common for causing missfires on the 6n2 polos. They are quite expensive, so that does sound about right. Ill check the part though. PM me your chassis number and ill check
You my friend have a pm!
just ran a vag com at the garage, cylinder 2 is mis firing so they have suggested changing spark plugs!
will keep you all posted
sorted, spark plugs replaced and the quick test run says everythings sorted! thanks for the help alex
Happy days
no worries dude
