6N2 1.0 Slightly High Idle
battax
Post by battax »
Greetings,
I have a 6N2 1.0 and i have a slightly high idle, at 900rpm more or less. The default value is 700 +/- 100rpm
With Vag-Com i had one error, Coolant Temp Sensor, that was changed.
The idle resumed to normal 200 Km´s after the sensor was changed, but today it reverted back to the same 900rpm.
At cold start it revs to 2000rpm for a few seconds and slows down after. Idle is constant there is no fluctuations.
I have no errors with vag-com. Did the Throttle Adjustment in vagcom too.
Any ideas? Vacuum hose? With the filter cover on, i didn´t found any leak.
I´m really out of ideas.
alexperkins
Site Admin
Re: 6N2 1.0 Slightly High Idle
Post by alexperkins »
Try cleaning the throttle body out with a decent carb/intake cleaning spray
battax
Post by battax »
alexperkins wrote:Try cleaning the throttle body out with a decent carb/intake cleaning spray
I´ve heard when the throttle body is dirty the idle is erratic, mine is constant, but soon i will try that.
When i change the spark plugs too, i´m using a Beru platinum sparking plugs, i will see the throttle body too and search for leaks on the intake.
battax
Post by battax »
Cleaned the TB and didn´t help.
I have the cambelt tensor coming to a end, it screams a little. Can it be the cause?
Other thing i was thinking was the air pressure sensor, not giving error now but a few years ago it dit, but it was gone after a few miles.
alexperkins
Site Admin
If the cambelt tensioner is screaming, get the cambelt and tensioners changed as soon as possible
battax
Post by battax »
alexperkins wrote:If the cambelt tensioner is screaming, get the cambelt and tensioners changed as soon as possible
Yep i know. what´s weird is that the high idle started at almost the same the cambelt tensor.
It will be the first time is changed, the car have almost 40.000 miles.
