Judder/stutter??
S.Kayani
Judder/stutter??
Post by S.Kayani »
Hello, was driving my car yesterday an noticed that the car was shaking a little after starting it - like the engine was about to stall or something - this disappeared when I put foot on gas.
But when driving the car felt like it was jerking a little on low revs I believe. Any ideas what it could be?
live1
Re: Judder/stutter??
Post by live1 »
i had this misfire at low revs.i changed spark lead no 3 .tested 1 at a time with a new lead.16 pound for a real oem lead is wot i paid.but chek plugs .maf sensor.coil pack aswel i cheked these before realising i t was only the lead
vdub10
Post by vdub10 »
hmm i had that other day after going throught water lol cleaned dizzy out and sprayed bit of wd40 job sorted
tom
alexperkins
Site Admin
Post by alexperkins »
these cars dont have dizzys tom :P its all electronic
its most likely either a spark plug failure, an HT lead is split and arcing or not connected, or the coil pack has failed
vdub10
Post by vdub10 »
o sorry dint realise. they say ya learn something everyday.
tom
S.Kayani
Post by S.Kayani »
Thanks for the replies, I'll check it out. Weather was decent yesterday - took it for a drive but it was alright I think - only juddered once while drivin along...I dono if that's another clue to what it could be? Maybe it's weather related - I'll drive it again an see how it is today
alexperkins
Site Admin
Likely to be an HT lead - take the all the leads out one at a time and inspect them. Any splits or damage to the lead tape them up with insulating tape for now, and get a new lead on order.
MrP
Post by MrP »
Get it vagcom checked... There is a measuring block which will tell the you misfire count on each cylinder.. I did this and it turned out to be misfiring on cylinder three.. Which was actually caused by the lambda.. Go figure...
But I would check the HT's first... Also check the coil.. Mine was missing a pin on the actual coil (had corroded off!!) and was causing a misfire..
S.Kayani
Post by S.Kayani »
I need to try and find someone with a VAGCOM in Notts. Are they expensive?
On a side note it's completely fixed - by itself! Dono why it did that?
I'll take it on a long run today - see how it goes
alexperkins
Site Admin
if its a lead, the weather can make it behave better or worse due to moisture
MrP
Post by MrP »
S.Kayani wrote:I need to try and find someone with a VAGCOM in Notts. Are they expensive?
I'm in Sheffield which isn't too far... So if your ever about drop me a PM and I'll vagcom it..
S.Kayani
Post by S.Kayani »
Ahh top man!
I'll have to arrange to come up sometime :-)
I think ur probably right about it being a lead then, because it's been driving good recently
