How to remove steering wheel
Hi guys i got my tracking done yesterday and my steering wheel is slightly out, how do i remove it in order to align it?
Re: How to remove steering wheel
Christ third time in three weeks. I wish people would search!!!
Anyway:
Anyway:
alexperkins wrote:To get the airbag out successfully it's easier to remove the under tray where the steering wheel is, and when you are releasing hhe airbag don't push the screwdriver in too far. You need to push the handle up into the steering wheel so the other end is going downwards. When you try it you'll see what I mean, but its easy to remove...if you try too hard, it becomes a real pain in the ass
Alex i did search im still quite unsure of how to remove it, as were playing with airbags here
what do u mean remove the undertray?
i thought the case was to disconnect the battery
then push two screwdrivers behind the steering wheel in the holes, this will pop out the airbag?
Underneath the steering wheel there is a plastic cover -you need to unscrew and remove this
Disconnect the battery, and follow my previous post instructions - they work
