9n3 gti aligning headlights
Jeff GTi
Post by Jeff GTi »
just installed my hids4u ultimate 5000k headlights over the weekens, look stunning but seem to point lower to the road than my original halogens
how do i go about raising them a bit,
i know inside the car, the electric adjuster is as high as it goes
and, i also know there are adjusters on top of the headlights, but do these adjust the light's height, and if so, which way do i turn the allen key shaped cutout in order to raise them up a bit
chris meardon
Re: 9n3 gti aligning headlights
Post by chris meardon »
Mines too high at the moment, this information would be useful
Turbomier
Post by Turbomier »
you mean adjusting the headlights without the use of the hight adjust button inside of the car on the dash?
so basicly, adjusting the lights...
there is a screw on youre headlight if you open the bonnet.
i'm not 100% sure but i thought it was a tork screw.
this screw is the one you need to raise or lower the headlight vision.
if i find some time and think about it i'll post pictures.
if this is what you mean :?:
about the direction, i thought if you turn left to right the light raises,
and if you turn from right to left it lowers.
park it in front of a wall and draw a line on it, turn on the screw and you will see wich way it goes, easy. :wink:
POLOZ
Post by POLOZ »
I think it would be better to get it aligned properly by a professional mechanic using the specialist equipment. Better to
save yourself some hassle instead of failing the MOT ;)
As Turbo said above, by using a garage door you could mark yourself some reference points and adjust accordingly
through the screws located on the back of the headlamp think somewhere top?!?!?
Alex_White_Gti
Post by Alex_White_Gti »
Think I've got to agree with POLOZ mate... My new bulbs did the same and I had to go to a garage as I couldn't do it. Your probably more patient than me though :-)
Awsome is next door to you.... Sure they would do it for for you for pence mate.
Alex.
