Painting Interior Dash? Dash removal?
b1ondie86
Post by b1ondie86 »
I'm sure I've seen somewhere how to take apart the dash so you can paint the air vent surrounds to colour code the interior etc. but I can't remember how I found it? Can anyone provide a guide on this? Also, I'm not sure what kind of paint would be suitable, I'm guessing you would probably need to layer it with a primer and lacquer - if anyone is anymore knowledgable about this than me(that would be most people), it would be a huge help.
Lol, I'm already causing chaos on this forum with all my questions...sorry peeps :oops:
Turbomier
Re: Painting Interior Dash? Dash removal?
Post by Turbomier »
in the near future i'm going to do the same thing.
i will find out how the get everything loose, but a guide would be verry helpfull indeed :mrgreen:
only thing i don't get is the climatronic, can the grey plastic cover be taken off?
i have tried this but i don't think this is possible :?:
i might be needing some info on this as i don't know how it can be removed :|
sorry for invading this topic, thx for help in advance :wink:
blazeguarder
Post by blazeguarder »
Turbomier wrote:only thing i don't get is the climatronic, can the grey plastic cover be taken off?
Yes it can, you need to get a thin bladed screwdriver in at one side and lever, and then do the same on the other side to get it off.
I don't know about the air vents, but the centre console goes something like this:
  • Remove the radio, top storage tray, card holder, cup holder and climatronic plastic cover.
    There should be 8 Torx bolts, 2 by the climatronic controls, 2 by the storage tray, 2 behind the radio and one behind both the card holder and the cup holder.
    There are also 2 Torx bolts under the climatronic panel which need to be removed.
    Push out the switches for the hazard lights and the rear demister from the back and unplug them.
    Remove the centre console.
Haynes describes it pretty well to be honest, but hopefully that description will help you guys out 8)
beijing polo
Post by beijing polo »
not sure about the vents,but i found a guide how to remove the center dash, i hope this helps!!
b1ondie86
Post by b1ondie86 »
Thanks Beijing, once translated that website is really good! Let's see - I found changing the indicator holder from orange to whatever colour you like (think I'll be trying that one), centre and lower console removal (wahoo!), installing Skoda chrome door pins (defo doing that at some point) and changing that little red LED light on the door locks to blue!
lm_gauci
Post by lm_gauci »
Vaglink sell the vents and centre console, i think its the same as the gti.
http://www.vaglink.com/VAG/Polo_9N2_9N3 ... N2_9N3.htm
Theres the link, they do a few other bits also.
b1ondie86
Post by b1ondie86 »
Hmm, I reckon I'm going to do a vaglink order soon...Got my eye on the chrome honeycomb grille and a cubby box.
Turbomier
Post by Turbomier »
mind you that it's only for the climatic version, not for climatronic.
found this a while ago, to bad, it would sell better if they had a version for the climatronic :|
