VAGCOM Errors...
MrP
VAGCOM Errors...
Post by MrP »
Wow... Well, my car has been a little thirsty as of late...
My VAGCOM threw up these errors:
I'm assuming I need a new Pre-cat lambda.. What abouth the coolent sensor, anyone know which one it is for?
VAG-COM Version: Release 409.1-US
Chassis Type: 6N - VW Polo
Scan: 01,02,03,08,15,17,19,25,35,41,45,46,55
Address 01: Engine
Controller: 036 906 033 D
Component: 1.6l/4V SIMOS3 00HS3512
Coding: 00031
Shop #: WSC 00788
WVWZZZ6NZ1Y222735 VWZ1Z0Y1169100
4 Faults Found:
16556 - Fuel Trim: System Too Rich: Bank 1
P0172 - 35-10 - - - Intermittent
16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
P0130 - 35-10 - - - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
17658 - Fuel Level too Low
P1250 - 35-00 - -
Readiness: 0000 0001
Address 03: ABS Brakes
Controller: 6X0 907 379 C
Component: ABS/EDS 30 IE CAN V004
Coding: 15603
Shop #: WSC 00788
Address 08: Auto HVAC
Controller: 3B1 907 044 C
Component: CLIMATRONIC C 1.0.0
Coding: 04001
Shop #: WSC 00788
Skipping Address 15-Airbags
Address 17: Instruments
Controller: 6N0 920 904 K
Component: KOMBIINSTRUMENT BOO V09
Coding: 00444
Shop #: WSC 00001
1 Fault Found:
01039 - Coolant Temperature Sensor (G2)
30-10 - Open or Short to B+ - Intermittent
Address 19: CAN Gateway
Controller: 6N0 909 901
Component: Gateway K<->CAN
Coding: 00022
Shop #: WSC 00788
Address 25: Immobilizer
Controller: 6X0 953 257
Component: IMMO 0008
Coding: 00001
Shop #: WSC 00000
Address 45: Inter. Monitor
Controller: 6N0 951 171 C
Component: Innenraumueberw. 0003
Address 46: Central Conv.
Controller: 6N0 959 799 B
Component: 8U Zentral-SG Komf. 0001
Coding: 04096
Shop #: WSC 00219
1 Fault Found:
00955 - Key 1
09-10 - Adaptation Limit Surpassed - Intermittent
Address 55: Xenon Range
Controller: 6N0 941 273
Component: Leuchtweiteregelung 0001
Coding: 00002
Shop #: WSC 00788
End --------------------------------------------------------------------------------------------------
emma_88
Drives: 6N2 Polo GTi & 9N3 Polo GTi
Re: VAGCOM Errors...
Post by emma_88 »
See the link for info about the coolant fault..
http://wiki.ross-tech.com/wiki/index.php/01039
alexperkins
Site Admin
Post by alexperkins »
Check the wiring going to the precat lambda - i got these faults, and it ended up being damaged wiring and broken wiring on the connector near the manifold
As for the temp sensor, just replace the green temp sensor on the thermostat housing and that error will go away.
MrP
Post by MrP »
Changed the coolant sensor.. All errors have gone!!
I did repair the wiring (well, solder a new connection on) not too long ago., it was my first check so it's all fine... Could it not have been over fuelling due to the coolant sensor?
I cleared all the codes and nothing has come back in about 50 miles.. although it still seems a little thirsty?
Anyone know what that central conv. Thing is?
alexperkins
Site Admin
Central convenience controls the windows, central locking and alarm and a few other bits
Did you use the gold repair wires? The silver ones arent up to the job on lambda connections.
Ah good :)
MrP
Post by MrP »
alexperkins wrote:Central convenience controls the windows, central locking and alarm and a few other bits
Ah good :)
Didn't use the gold repair wires, I used a spare section/clip I had from an mates spare gti loom.. It's a good repair though and is still intact.
The car is still over fuelling and throwing up the Error of fuel system too rich on bank one.. The lambda fault however has gone...
Any ideas why it's still over fuelling?
alexperkins
Site Admin
Could be many things. check the fuel filter for one. Whats the error code you are getting?
MrP
Post by MrP »
alexperkins wrote:Could be many things. check the fuel filter for one. Whats the error code you are getting?
As above.. 16556...Fuel trim..
alexperkins
Site Admin
ill look into this...
MrP
Post by MrP »
alexperkins wrote:ill look into this...
Cheers dude... I'm getting less than 20mpg driving like a Grannie!!
Oh, the fuel filter is 3 months old too!
alexperkins
Site Admin
Thats a little worrying!
fair play
MrP
Post by MrP »
alexperkins wrote:Thats a little worrying!
fair play
Tell me about it, especially since I do 250 miles a week!!!!
MrP
Post by MrP »
Anyone?
Even if its how to diagnose the Lambda/fuelling using VAGCOM would be helpful... Like the optimal reading etc..
alexperkins
Site Admin
give me a chance!
MrP
Post by MrP »
alexperkins wrote:give me a chance!
Sorry big dog :oops:
