http://www.ultraleds.co.uk/dual-ultimat ... -1429.html
Does anyone know whether these will fit in the FK Angel eye sockets or are they too wide?
FK angel eyes LEDs.. will these fit?
- red6n2
Re: FK angel eyes LEDs.. will these fit?
hiya i went through all the hastle of this before il see if i can fiond my old thread.
- red6n2
https://www.crazyleds.co.uk/home.php?cat=6
these are the ones i have, and heres a pic of them...
plus in that pack i think you get two spares, the job of changing them is a bit more involved than it seems specialy as once youve pulled the bulb holders out they ae loose and dont ever seem to go back in properly. and are a pain in the ass to get to
the previous thread is called powerlook angel eyes. hope that helps.
Thanks for your reply red6n2
Reason I'm asking is that I've got LEDS quite similar to yours installed ATM, but I find they keep failing every now and then because they 'vibrate' out of their power sockets. Also, I was looking at that particular LED in my first post because it produces more light with 2 bulbs stuck on it. I find my current ones to be quite weak light-wise. How are yours in terms of luminosity red6n2? (a bit hard to judge with pics!)
Cheers PH-VAP
Cheers PH-VAP
- red6n2
these are probably as good as your going to get from bulbs this small just tried to take some pics of thier illuminosity these dont come out thier socket but the bulb holders do come out of place as there seems to be no clip or anything holding them there and at the weekend i shall be setting them all in right and proplerly.
here is just my sidelights lighting my mums car about a meter and a quarter away.
and again my hand about a meter away.
again there not bad for sidelights and bear in mind some of mine arent on i think in total i have 3 bulbs which arent luminated in the rings due to the holders being crap, and my headlights are caked in dirt which probably dosent help.
any other questions just let me know bud
Thanks again for the reply and pics Red6n2!
Still find it a bit hard to judge how bright your LEDS are from the pics!
Do you find that when you have them on during the day they look like 5 seperate dots of light, or is the ring clearly illuminated as well?
And would you happen to have a pic of them without the flasher on your camera?
Sorry for all the questions! Just trying to work out whether its worth to get a new set
CHeers,
PH-VAP
CHeers,
PH-VAP
