cars limited to 80mph
- red6n2
ok this may sound stupid but ive seem to have lost a lot of acceleration and my car has limited itself to 80mph
i didnt think these could even do that... was on the m1 last monday and the engine light flashed at me for roughly 5 seconds then it reduced in speed and now wont pass 80mph ???? any one got any ideas ?
- bstardchild
- Moderator
Re: cars limited to 80mph
2 starts and as long as the fault has gone it should reset itself - it's limp home mode and you are right it does seriously limit speed and accelerationred6n2 wrote:ok this may sound stupid but ive seem to have lost a lot of acceleration and my car has limited itself to 80mphi didnt think these could even do that... was on the m1 last monday and the engine light flashed at me for roughly 5 seconds then it reduced in speed and now wont pass 80mph ???? any one got any ideas ?
If you have vag com you can see what codes are in memory
- red6n2
Il see if I can get that done as a temporary fix but does anyone have an idea as to what caused the problem in the first place ?.
- bstardchild
- Moderator
Could be a 101 things - only with a scanner like vag com can you find out the codes resident in memory once you have codes you have potential answersred6n2 wrote:Il see if I can get that done as a temporary fix but does anyone have an idea as to what caused the problem in the first place ?.
- red6n2
ah thanks il try and get the eror codes and go from there,
- bstardchild
- Moderator
HJas it gone back to normal after a couple of starts or still the same?red6n2 wrote:ah thanks il try and get the eror codes and go from there,
- red6n2
its still the same, little jumpy slow as anything and still limited to a max speed of 80 lol i realize 80mph anywhere is still speeding but its making overtaking more effort than its worth as the acceleration is so bad and its just annoying not having the option to go faster...
- bstardchild
- Moderator
Then the fault is still there - vag com neededred6n2 wrote:its still the same, little jumpy slow as anything and still limited to a max speed of 80 lol i realize 80mph anywhere is still speeding but its making overtaking more effort than its worth as the acceleration is so bad and its just annoying not having the option to go faster...
its likely to be a cam or crank sensor, but you need vagcom as bstardchild says to diagnose the fault properly.
- bstardchild
- Moderator
I've got a copy but I'm not exactly near Northampton - might be worth a shout out to see if anyone more local to you has one and would be prepared to code read the caralexperkins wrote:its likely to be a cam or crank sensor, but you need vagcom as bstardchild says to diagnose the fault properly.
- red6n2
il go to my step dads mates garage when it reopens see what they say.
no one on here lives anywhere near me most people are southern... the only time ive ever seen the english sea is when im 30,000 feet up in an aeroplane lol.
but if anyone does live near nthmpton and has VAG COM it would be greatly appreciated if i could borrow your time
