I'm just need abit of assistance, my polo's missifiring
i recently serviced her, oil/fuel/air/rotor/dizzy cap
she ticks over fine, but there is a intermitent misfire/hessitation not sure if its the service or weather its a coinsidence thats the problem happen at a simular time
Seems to get worse whens shes up to tempreature
I've checked the fuel fitlers on the right way around, both pipes are clamped on tight
I've changed all the leads and plugs
also found a fuel pipe clamp missing from the sender, so replaced this,
checked the firing order/ lead positons on the cap, all okay,
so I'm a bit stumped, anyone else got any common faults or ideas that I've missed?
there was also some oil residue around the air box seal? and dint seem a great deal of vacume when i took the induction pipe off and covered it over, suggesting shes sucking air from else where? just i can see any ovious perishing or splits etc
also fitted a new temp senor, mines a 4 pin one witha yellowish ring? not the blue one like most vw?
tried various MAP sensors, still no luck
the 3 fault codes on there are
00533 idle speed regualtion
00519 intake manifold preasure sensor
00522 coolant temp sender
many thanks in advanced,
danny
