Gear Scyncro
drennan
Gear Scyncro
Post by drennan »
grinding noise from 1st gear going into 2nd at high revs.Gear Scyncro? Anyone know whats envolved in fixing it? expensive one? who else does it apart from verve? and would i be aswell getting the 6 speed lol
Hope this isn't alot to ask. cheeers guys!
DURKY
Re: Gear Scyncro
Post by DURKY »
Hi pal,
Mine had same problem good thing about mine was it was under warranty!
The box has to be taken out and stripped down mine needed other parts such as full gears replaced and some bearings inside .
Then took them 6 attempts to seal the box fully! It's not a 5 min job and Vw charge nearly 500 just to take the thing out!
drennan
Re: Gear Scyncro
Post by drennan »
purchased a engine mount maybe fix it maybe not lol
DURKY
Re: Gear Scyncro
Post by DURKY »
Won't fix it mate had that problem as well that just clunks and knocks not crunch it's most definelty synchros
LeMeph
Re: Gear Scyncro
Post by LeMeph »
I had it too! fixed under warranty last year, the syncro mesh goes in them. somthing to do with vw putting the wrong gearbox oil in them from the factory! There was a recall on them thoguh so i dont know if you could get it sorted out maybe??
Go down to the stealers and ask them :-) its definately your problem! thoguh i dare say a six speed couldnt hurt you either lol
9N3 Turbo
Re: Gear Scyncro
Post by 9N3 Turbo »
Go 6 speed :mrgreen:
Couldn't live without mine now 8)
drennan
Re: Gear Scyncro
Post by drennan »
"9n3turbo" much did you pay for the parts for the 6 speed? you work for verve dnt ye? got a pal that mite be able to sort it.The thought had crossed my mine lol did u end up gettin it coz ur scyncro has went aswell?
drennan
Re: Gear Scyncro
Post by drennan »
failing that I may ask down at the stealers bout this recall cheers "LeMeph"
LeMeph
Re: Gear Scyncro
Post by LeMeph »
No worries dude! Only thing i dont know is if they will then fix your gearbox for free due to the recall or if you will have to pay... No ideas!
Luckily i never had to find out, mine had the recall done a year before but obviously too late as the box went anyway!
9N3 Turbo
Re: Gear Scyncro
Post by 9N3 Turbo »
drennan wrote:"9n3turbo" much did you pay for the parts for the 6 speed? you work for verve dnt ye? got a pal that mite be able to sort it.The thought had crossed my mine lol did u end up gettin it coz ur scyncro has went aswell?
HI Drennan,
I was lucky to find the gearbox on ebay for just £180 :mrgreen:
The gearbox goes straight in and the drive shafts bolt up too.
The only mod i had to do was a slight mod to the chassis leg as a small part of the box sits about 2mm from the leg various ways to get around this though.
Verve? dont know who that is. Don't work for or with this company.
Did it all myself with the help of a friend.
Changed it just because i wanted a 6 speed.
My 5 speed was and still is fine just sitting the the cupboard for a rainy day.
drennan
Re: Gear Scyncro
Post by drennan »
Ah ok cheers guys! one other thing I take it there was only one 6 speed box from the polo 1.9tdi?
9N3 Turbo
Re: Gear Scyncro
Post by 9N3 Turbo »
drennan wrote:Ah ok cheers guys! one other thing I take it there was only one 6 speed box from the polo 1.9tdi?
I used a Golf MK5 2.0 FSI 6 speed gearbox.
I haven't seen the gearbox from the Polo 1.9tdi but if you get a couple pics of it i could tell you if it's the one.
9N3 Turbo
Re: Gear Scyncro
Post by 9N3 Turbo »
None of these are what you are after.
You need it from the Mk5 Golf 2.0 FSI (non Turbo) or Audi A3 2.0 FSI (non Turbo).
The box looks like this
drennan
Re: Gear Scyncro
Post by drennan »
Ah ok thanks alot man! I may contact you nearer the time if thats ok......gonna do my fmic 1st which has been ordered :D
