Should it happen to anyone else … the problem was solved by rejoining it using a short piece of ⅛” brass tube and an hairdryer to soften the hose.
Ray
Washer tube to rear split in passenger side footwell
Re: Washer tube to rear split in passenger side footwell
Think this has broken on my sisters 1.4, where abouts did you gain access to it from mate?
Access from inside the car under the glove box ... nothing to remove ... the tube will have been broken by someone's foot ... it's badly positioned.
Ray
Ray
Ray i had a look but couldnt see no tube, i know mine has also come off, they normally tend to come of from the back boot area but i double checked that and it was fine there and the leak is towards the passenger side underneath the car at the front. Any chance of providing some pictures or abit more help where exactly am i to look.RayD wrote:Access from inside the car under the glove box ... nothing to remove ... the tube will have been broken by someone's foot ... it's badly positioned.
Ray
Much appreciated
Not alone mate, our 9n3 1.2S had exactly the same problem!
Excuse the picture quality … taken in the dark.
To get a better idea of the position ... all the white marks above the carpet will have come from passengers feet.
While taking the photo I found the plastic pipe had come off one end of the brass tube so I need to find a better solution and perhaps fit a guard around it.
Ray
Ray
Ray your the MAN!!! Thanks so much, Now going to have a look because its a right pain when your rear washer is not working!!
i connect my amp wires through that hole haha
Hope those wires are watertightzedzo wrote:i connect my amp wires through that hole haha
my back washer aint working all of a sudden checked the pipe underneath glove box seems to be connected i did notice air bubbles in the bottle so i may have a split pipe due to freezing weather perhaps? couldnt have a look at it due to bad weather today
