Sprayed front lip
Sprayed front lip
Hey guys, this is a small diy job, what do you think?? i mean the front lip, the one under the bumber. just costed me £8
k&n filter 57i
i got this new mod as well
carmadaaron
- bstardchild
- Moderator
I like the front lip painted
Picture removed
Regarding the filter - Think it might be too much warm air - here remeber the engine sucks down the intake so you need to have a much bigger cold feed to compensate for lack of suck and p*** poor ram air effect
But I wasn't sure about the rear light masks - never seen them before
Picture removed
here are the links http://www.alfa145.com/upload/cm6.jpg for the lip
and this is for the k&n 57i induction kit
http://www.alfa145.com/upload/cm9.jpg
bstardchild: that black pipe there (pointing towards the filter) takes cold air from underneat the car. i had to mod the front grill, the one just above the lip to make it suck cold air.
here is a small picture to show you from where exactly.
http://www.geocities.com/balinju/car/frontshown.JPG
i know it works because now it is quite a long time that i fitted it, and the place where the black pipe is point towards is filled with dirt, while the other side, it is completly new!! so i can be assured that it is sucking cold air
PS. if the links do not work for you, add a space at the end in the address bar and press enter, they should work now.
thank you for your comments
carmadaaron
no i don't think so. I don't like lexus lights on white. i have already something on my back lights, look:
next on my wish list is a sound system. I already got a cd/mp3 stereo and a 375W amplifier. i just need a subwoofer (my wished one is an infinity kappa perfect 12.1) and a set of components. i think i will buy a set of focal polyglass. i am not going for an SPL sound system, i would like an SQ one. at the end of summer i should have collected enough money for everything. i also got a white dial kit, but not fixed in its place for now, which i will do after exams end, and then i will post pictures for you to see. i also have in mind to change all green light to blue inside. what do you think?
- bstardchild
- Moderator
