Polo battery/ starting issues! HELP NEEDED PLEASE
TimGti
Drives: 9n3 1.9 Tdi Sport
Post by TimGti »
With no prior indication our Polo wouldnt start today. Battery was completely flat to the extent dash lights wouldnt even show! I jump started it using our other car and took it for a 10 minute drive and the battery had held some charge as I was able to turn the car off and resart it a few times, use the headlights, radio etc. I assumed I'd just left the parking light on for 48hrs by accident or something.
However, went back out tonight after leaving it standing for 6 hours and its flat again. Dash lights work, but doesnt seem to be enough charge to start the car. The dash makes a clicky sound when trying to start. Now I didnt drive the car for ages today to re-charge the battery, but it started fine a few times after a 10 min drive and shouldnt have any less juice 6hrs later surely!
If the battery was faulty Im assuming I'd have had some warning of starting issues prior to today & Im also assuming it wouldnt charge when driven, which it does. Therefore something must be draining it :?
As a side note, a few other electrical gremlins have occured lately. Namely the stereo cutting out randomly, and the dash lights not working when turing the headlight switch on (albeit only a couple on times).
Any help much appreciated! Where do I start? :?
Tim
alexperkins
Site Admin
Re: Polo battery/ starting issues! HELP NEEDED PLEASE
Post by alexperkins »
Batteries can just die just like that. Once they are totally flat, unless you take it out the car and put it on a proper slow charger, theres no way to get it back to capacity as the alternator cant provide a high enough amperage
jonnopolo
Post by jonnopolo »
This has happened to me too in my X reg Polo Match. It seems to do it when it's cold; I may leave it for a week (in the garage), then try to start it but I just get the clicking noise. I then charge it up and then it fires first time. The battery I have now is not even a year old and it is a Halfords Calcium with a 4 year guarantee. It happened to the previous battery that was also new, when we had cold weather last February. This was when I changed it for the Calcium type. In the summer I can leave it for 2 weeks and it starts up with no problem. I've checked the battery with a multimeter to check alternator is charging OK and with all the lights, blower, rear screen heater all switched on, the battery is showing approx 14v., so I'm completely baffled.
TimGti
Post by TimGti »
Well I got a booster to get it going again and went for a 20 mile drive. Its now fine! Been a couple of days now of using it daily again and it seems back to normal! I reckon I might have just left the parking light on and didnt give it enough of a run to get any charge back into the battery the first time I jumped it :roll:
Fingers crossed it stays good.
