**HELP, CAR OIL LIGHT COMES ON ENGINE CUTS OUT WITH BEEPING*
Over the last couple of months my 6n has been running like a dream until one night i was on my way home doing a steady 60mph on duel carriageway, and a beeping sound started and the oil light came on and the engine cut out and lost all revs. I managed to get home and we checked everything out. A few months later it happened again. Once you take the key from the ignition and re-start the car it seems fine! Just need some advice on what this could be!
- bstardchild
- Moderator
Re: **HELP, CAR OIL LIGHT COMES ON ENGINE CUTS OUT WITH BEEP
Eitheremmie2511 wrote:Over the last couple of months my 6n has been running like a dream until one night i was on my way home doing a steady 60mph on duel carriageway, and a beeping sound started and the oil light came on and the engine cut out and lost all revs. I managed to get home and we checked everything out. A few months later it happened again. Once you take the key from the ignition and re-start the car it seems fine! Just need some advice on what this could be!![]()
One of the oil pressure sensors (from memory there are two) is starting to fail
The connectors on the back of the instrument pod aren't tight
Where abouts are the pressure switches located?
