LED Sidelight, Warning on dashboard?
ChunSel90
Post by ChunSel90 »
Hi all,
I recently fitted some LED sidelights, and theres a warning on my dashboard, regarding the light bulb
Is this because the LED runs using less V, so hence the computer thinks the bulb has blown?
Is there anyway to get rid of the warning light?
Edi30
Re: LED Sidelight, Warning on dashboard?
Post by Edi30 »
You will need to get some different LED's. I had the same problem had LED's with Can-bus and still had the same problem so put normal bulbs back in. Some of the others on the forum have managed to install LED's that don't cause this issue. Good luck in getting this sorted.
ChunSel90
Post by ChunSel90 »
yeah i think i just read that thread, one with the red GTI? hmmmms, ill try changing them around on the weekend and see if it works, mine are same as yours atm, without ignition its fine, with ignition on, the warning appears on the rev counter, i wonder if VW could remove the error? so it stops, will find out.
Is there any danger with regards to driving around with the warning light on though?
alexperkins
Site Admin
Post by alexperkins »
You need canbus friendly LEDS to get the error to go away
Edi30
Post by Edi30 »
alexperkins wrote:You need canbus friendly LEDS to get the error to go away
I tried can-bus on mine and the ones I tried still caused the bulb warning.
alexperkins
Site Admin
Some canbus LEDs arent truly Canbus friendly - beleive me. Been there done that :(
Edi30
Post by Edi30 »
alexperkins wrote:Some canbus LEDs arent truly Canbus friendly - beleive me. Been there done that :(
I do and need to try some others.
ChunSel90
Post by ChunSel90 »
alexperkins
Site Admin
aye
Blaade
Post by Blaade »
ChunSel90
Post by ChunSel90 »
Finally sorted it! :D!
got some Can-bus LED's and they look spot on now :D!
Thanks for the help people!
