Camber help
bfc1882
Camber help
Post by bfc1882 »
Hi guys wondering if anyone can help? I am running ap coilovers and standard rims and my tyres are shot after 5k on the inner edge. Is there anyway to adjust the camber or is tyre wear just one of the downsides of lowering your car. It is as low as it will go on the back and the front is level although could go a lot lower. I had the tracking done when I lowered it but 5k out of a set of fronts is garbage. Any help appreciated
g__humm
Re: Camber help
Post by g__humm »
Bushes on front worn maybe. Or if you had the tracking do e before the coilovers were put on you may find it needs doing again.
I have lowered my 9n round 100mm on ap and I get more miles than that to a set of tyres
bfc1882
Re: Camber help
Post by bfc1882 »
Cheers mate I will get those bushes looked at. Tyres used to wear fine before lowering it though so might get them to check tracking again although it has been done since lowering. Would raising the suspension a little bit help reduce camber much?
g__humm
Re: Camber help
Post by g__humm »
Yer but mine is seriously low and camber has not masivly killed tyres
bfc1882
Re: Camber help
Post by bfc1882 »
What tyres are you using? I have Toyo proxes
bfc1882
Re: Camber help
Post by bfc1882 »
Anyone else have any ideas?
noone025
Re: Camber help
Post by noone025 »
Did you get a wheel allignment?
bstardchild
Moderator
Re: Camber help
Post by bstardchild »
noone025 wrote:Did you get a wheel allignment?
^ This
Tim_GTi
Post Whore
Re: Camber help
Post by Tim_GTi »
You HAVE to get your wheels aligned after you've lowered the car, the tracking and camber will inevitably be out.
bfc1882
Re: Camber help
Post by bfc1882 »
I did have it aligned after lowering but it seems that my bushes were shot. Got some cupra one fitted so hoping problem solved. Cheers for the responses
