Automatic hatch? Anyone?
So, I saw these cool hatch-openers that made the hatch pop open when you pressed the unlock button on your remote.
However, I could only find them for the Golf. Does anyone know if you can get the for the Polo??
Here they are:
http://www.ecstuning.com/Volkswagen-Gol ... ES1895197/
https://www.youtube*.com/watch?v=nzrbrMJW ... re=related
http://volkswagenownersclub.com/vw/show ... ch-Pop-Kit
Some also claim it's needed to do a VAG-com programming.. Don't know if that is the case for all the kits though. I guess it's because you need the car to "open" the hatch, not just unlock.
Anyways, looks awesome!
Here they are:
dood9n3
Re: Automatic hatch? Anyone?
It does need vagcom coding
- blazeguarder
Vag-com aside, I don't really see why this wouldn't work. It uses Fabia gas struts, which is a car based on the Polo, so it's not like it's going to not be able to take the weight of the tailgate or over-open it or anything... Then it's just the Scirocco springs that force it open till the struts can take over.
Might be worth a trip to the dealers to see how much those parts are direct, as that supplier has probably put a mark up on them... $110 is a bit steep for an auto-opening boot lid!
kc
- Drives: an imaginary one... for now
i reckon if you can get some of the scirroco bump stops with the 'spring effect' type doodah it should work
it doesnt need vag-com cos we've already got the boot pop on our polos! winner!
Sweeet^^
Would be awesome. The car looks way more expensive then imo, hehe.
So it just might work by buying those I linked to?
- blazeguarder
Do you guys have the boot pop already activated? Mine just unlocks the boot when I press the button, still need to pull on the handle to open it...kc wrote:it doesnt need vag-com cos we've already got the boot pop on our polos! winner!
kc
yehhhh......No... lol i got confusedblazeguarder wrote:Do you guys have the boot pop already activated? Mine just unlocks the boot when I press the button, still need to pull on the handle to open it...kc wrote:it doesnt need vag-com cos we've already got the boot pop on our polos! winner!
i thought it did, but its not that, its my Passat that has it
not the polo.... not sure if this will work or not
- blazeguarder
Hmmm, looks like we need someone with vag-com to read this and check if it's possible to recode the boot latch so that it opens instead of just unlocks...
*waits patiently*
*waits patiently*
I'm 90% sure it will work, but I got no tools to check.
Read first link it needs the vag com adjusting
K.I.T.T.
- Platinum Member
- Drives: Bicycle
As long as you have the 3 button fob, you don't need to code it. It's just struts with a bit more tension / force. Just beware of any objects in the vicinity of the hatch before you pop it.
I've seen it done using OEM parts (possibly a strut from a Fabia), but didn't look into it further.
I'll get back on the case!
Ash
Ash
K.I.T.T.
- Platinum Member
- Drives: Bicycle
Ok, apparently I was wrong.
Read (and try to make sense of) this: http://translate.google.co.uk/translate ... rmd%3Divns
Ash
edit: Page 7 onwards...
Ash
I don't get it
dood9n3
Tried with vagcom, the coding is not there
You see the option in the drop down in 2nd pic, then I get error in first pic
