Looks like your going to beat me to itMODDED9N wrote:Doing centre console tonight if time permits
I'm waiting for a large sheet to be delivered so that I can do this!
You need to remove the radio, storage tray, cup holder, card holder and the heater control surround. Push the switches out from the inside and unplug them. There are 10 torx screws that need removing, 8 are easily visible and the other 2 are under the centre console. If you have climatronic, then you need to remove the screws from underneath before removing the climatronic panel as otherwise you can't remove it. If you have climatic, you don't need to remove the controls themselves, just the surround. The centre console can then be lifted off.MODDED9N wrote:Trying to see right now how to take the centre console off! Any ideas? Cheers
good luck!!!MODDED9N wrote:Doing centre console tonight if time permits
