VAG COM Codes?
VAG COM Codes?
I purchased VCDS-Lite in order to sort my retro fit Cruise Control out, which was pretty simple.. I found some instructions that just said "Login with 11 463"
So I did, and all was sweet with the Cruise Control
Is there like some kind of archive somewhere with similar login codes to do other stuff?
Like Central locking, anti-hijack ect?
Would be quite useful to maybe see some sort of list with codes on how to do each one?
Ste
Ste
- blazeguarder
Re: VAG COM Codes?
+1 for this. I'm toying with the idea of getting VAG-com at some point in the near future and having a list of possible codes to use would be excellent. Maybe a mod could make it a sticky if it gets going?
Re: VAG COM Codes?
You dont need to login to change CL and anti hijack settings
Go into the Central Convenience module then Adaptation
login is only for recoding modules to accept new hardware installs.
Re: VAG COM Codes?
Cheers Alex, never realised what the adaptation was for!
I thought logging in was the only way to change settings
I found the anti-hijack on channels 03 (Auto Lock) and 04 (Auto Unlock) but still can't seem to see the Central Locking 'one button' feature
Can you remember what channel it is or what it's called in the Central Conv. > Adaptation?
Re: VAG COM Codes?
Its called selective unlocking
If its not in there, try central electrical
K.I.T.T.
- Platinum Member
- Drives: Bicycle
Re: VAG COM Codes?
46 Central covenience
07 Recode
It should be 00064. Change it to 00065.
Ash
07 Recode
Ash
Re: VAG COM Codes?
Mine wasn't 00064 to start with but I changed to 00065 and it works great!K.I.T.T. wrote:46 Central covenience
07 Recode
Ash
Cheers dude
K.I.T.T.
- Platinum Member
- Drives: Bicycle
Re: VAG COM Codes?
Weird. It's "supposed" to be 00064 (mine was), but all's well that ends well!
Ash
Ash
Re: VAG COM Codes?
Oh yes...i forget these cars arent full CAN lol
- Mart!n-GTI-DK
- Platinum Member
- Drives: '14 Polo BlueGT
Re: VAG COM Codes?
I thought the 'save' feature was blocked in the VCDS-lite version both registered and unregistered?
I wasnt able to save the changes for the anti-hijack feature in my GTI. Although i am using the cheap ebay version.
