Would Alloys from a 2011 Polo fit a 9N?
Fannon
Post by Fannon »
Just wondering if alloys from a 2011 Polo would fit a 2005 Polo 9N? 5 Stud with tyre size 165/55 R15.
Found a new 2nd hand set for a pretty good price with new tyres and wondering if they would fit, cheers.
Fannon
Re: Would Alloys from a 2011 Polo fit a 9N?
Post by Fannon »
Anyone?
zedzo
Post by zedzo »
there all 5x100 n so should fit yes.
Fannon
Post by Fannon »
Thank you!
K.I.T.T.
Drives: Bicycle
Post by K.I.T.T. »
Tyres are he wrong profile. They should be either 195/50/15 or 195/55/15. Look at the sticker stuck inside the fuel filler cap.
Ash :)
Fannon
Post by Fannon »
I just copied it from the ebay auction Ash, they must have mistyped the tyre size! Thanks for pointing that out!
Stuart
g__humm
Post by g__humm »
Aren't new dubs 5x112? I thought they were if so then u will need adaptors
Fannon
Post by Fannon »
I really need to know, iv been searching on sites and on all the alloy sites it just asks if its a 5 or 4 stud. Nothing about 5x100 or 5x112 or anything.
Fannon
Post by Fannon »
Got this from the wolfrace website:
Make: VOLKSWAGEN Model: POLO: Year: 09 - PCD: 5x100 Offset: 43>
Bore: 57.1 Fittings: M14x1.5 Recommended: 175/70R14
Ignore the tyre size, but it says the pcd is 5x100 which should be fine eh guys?
JoshGTI
Post by JoshGTI »
Et43 is a bit high for a 9N. You would need to run spacers. Might run ok but would sit back in the arch a bit more.
Fannon
Post by Fannon »
That ET43 is just from the wolfrace website, when you put in a 9n 2005 it comes up the same ET.
