VAGCOM VCDS
dantheram
VAGCOM VCDS
Post by dantheram »
Can someone help me out with either getting hold of the aforementioned or if you are near Derby and have VAGCOM or VCDS possibly hook up to my car?
Any help much appreciated,
Dan
dantheram
Re: VAGCOM VCDS
Post by dantheram »
After some research i have found the following stuff
Cable.
http://www.gendan.co.uk/product_VAGUSB.html
And Ross tech shareware.
http://www.ross-tech.com/vcds/download/current.html
If i buy the lead and run the software on my laptop will i have the ability to pull error codeson my GTI? :?:
alexperkins
Site Admin
Re: VAGCOM VCDS
Post by alexperkins »
Those leads are cheaper on ebay mate - just search VAGCOM 409.1 on there
You can pull a select amount of codes with the shareware version of VCDS lite but can change no settings
dantheram
Re: VAGCOM VCDS
Post by dantheram »
Not interested in the settings, just want to pull codes, worried about this limitation though. How severe is it?
Bradley
Re: VAGCOM VCDS
Post by Bradley »
General fault codes and the clearing of them VCDS Lite will be ok for that,as Alex said though,have a look on the bay for a lead to save some money.
