Rather Urgent Guys :(
Trunkz
Post by Trunkz »
OK.. So I got my brake line fixed today, and was driving back home on the A3. (70mph zone) Then suddenly, the EPC light comes on, and I immediately notice that the engine isnt giving any more power, and i managed to get onto the slip-road, and stick my hazards on as it crawled to a stop. I pop the bonnet open, and see that the hose directly to the right of the coolant sensor had popped off (explained below) and thus all my coolant had escaped on the A3.
The reason the hose had popped out is that I had forgotten to replace the O-Ring yesterday as I was renewing my coolant.
Now; the car wont run for more than a second. The car itself would start, hear the engine run for a second, then turn itself off. I've left the negative battery terminal off for a good 20 minutes in hopes it would reset this EPC light, but nothing. I need to FIX this by tonight, otherwise I wont be able to see the missus in kent tomorow.. and that'll just give her an excuse to give me an earful. :cry:
I've got one of those mechanics lights that hook onto the battery, so I literally will be working through this all night.
Trunkz
Re: Rather Urgent Guys :(
Post by Trunkz »
Update:
In the fusebox, there are three fuses marked for Engine Management;
F31 (Mini-blade 10A)
F36 (Standard 15A)
F37 (Standard 15A)
Removing fuse F36 allows the engine to start and keep misfiring? (I think thats what a misfire is, constant JUG JUG JUG JUG sounds) but nevertheless, stays ON. Removing the other fuses does nothing. I found relay 100 (supposedly for the ECU) situated behind the fusebox, removed that and put that back in hopes that might reset the ECU, but nothing came out of it.
Desperate to get this fixed..
neilGTI
Post by neilGTI »
It sounds like the car is in some sort of protective mode to stop you damaging the engine.
Have you replaced all the coolant that you lost ??
Have you got vagcom ?
Trunkz
Post by Trunkz »
I replaced all the coolant yes. Cant for the life of me find my vag com cable, so I ordered one off ebay again.
neilGTI
Post by neilGTI »
Its not something i have heard of before myself, hopefully Vagcom can help you out to fix it, doesnt help with your other half though i'm afraid
Trunkz
Post by Trunkz »
VAG-COM Version: Release 409.1-S
Control Module Part Number: 036 906 033 D
Component and/or Version: 1.6l/4V SIMOS3 00HS3512
Software Coding: 00031
Work Shop Code: WSC 00788
Additional Info: WVWZZZ6NZ1Y305453 VWZ1Z0A1478429
1 Fault Found:
17581 - Angle Sensor 2 for Throttle Actuator (G188) Signal too High
P1173 - 35-10 - - - Intermittent
Also, Immobiliser said this:
Control Module Part Number: 6X0 953 257
Component and/or Version: IMMO 0008
Software Coding: 00001
Work Shop Code: WSC 00147
1 Fault Found:
01179 - Incorrect Key Programming
35-00 - -
Okey, so I need to get my key paired to my immobiliser again. Anyone in surrey know a cheap mobile auto-locksmith (I live in Chessington). Dont want to tow the car to VW and pay extortionate prices. But more importantly, what is that first error?
P.S - I had other errors, but after clearing them, they didnt come up again.
neilGTI
Post by neilGTI »
Its a throttle body error, you could try cleaning it and see if that helps.
Trunkz
Post by Trunkz »
I used vagcom to do a throttle body allignment and its still not starting. I give up. Going to the mechanics.
alexperkins
Site Admin
Post by alexperkins »
Sounds like the immobiliser kicking in cutting the fuel pump
Trunkz
Post by Trunkz »
Are you sure? The auto locksmith came down and paired my key to the immobiliser. He even gave me the four digit immobiliser code if I wanted to pair anymore keys in vagcom.
Trunkz
Post by Trunkz »
Okey it definitely isnt the immobiliser. For some reason, the battery had died, so the mechanic jump started it, and it was running. However the engine was having constant fits. (Misfiring? Constant juddering?) He plugged in his diagnostic, and saw the throttle body issue. After a few minutes of fiddling with the throttle body, he told me I need a new throttle body. So now just picked up one of those off a chap @ clubpolo, and hopefully that'll be the end of it. Need to get some pictures of the GTi on here soon-ish :)
joe2612
Location: Guildford, Surrey, Drives: Polo GTI 6n2 Black
Post by joe2612 »
Sounds like the tb to be honest mate! shame i wasen't around could have given you a hand as i'm in Woking! Chris on here had a similar issue with his GTI and i supplied him with a TB and it was all happy days :D
neilGTI
Post by neilGTI »
Hope it all gets sorted with the new throttle body
Trunkz
Post by Trunkz »
2 Faults Found:
17524 - Oxygen (Lambda) Sensor Heating: B1 S1: Open Circuit
P1116 - 35-00 - -
17579 - Angle Sensor 2 for Throttle Actuator (G188) Implausible Signal
P1171 - 35-00 - -
Ignoring the lambda sensor, i'm still getting this damn Angle Sensor 2. Where is this sensor? I've just replaced the damn throttle body.
red6n2
Post by red6n2 »
Lambda sensor is the only error I get on vagcom if you ignore it surely petrol consumption is increased ?.
