Radiator Fan
Radiator Fan
Anyone know how to test the radiator fan on the 16v? I am pretty certain its the cause of my over heating problem but short of buying ahaynes manula I dont know which wires to bridge to force the fan on to test it.
BenMMellor
knew i should have paid a bit more attention when the AA was with me on friday morning. My 'stat' collapsed and I had no tools to remove it when I was over heating. (The joys of having an MGB years ago - teaches you a lot about cars !)
Check the bottom radiator hose is a warm as the top hose (The bottom hose sort of goes to the side of the engine.) You may have the same issue as we where the 'stt' is on it;s way out and may be blocking th eflow of cold water. They're only about £7 from Eurocarparts.
You are right that you can bridge the fan to test it though mine wasn't working till I removed the 'stat' as the sensor was not getting triggered.
IIRC the connector to test the fan plugs in near the left hand side headlight. Take it off and bridge the terminals. I'd check it for you now but my cars in getting the HG pressure tested and the 'stat' replaced. I'd do it myself but a) haven't got time and b) it's what a warranty is used for.
BenMMellor
