hi there, i dont knw how to go about these faults that i picked up on my car. so if possible can someone help me with these codes, my car is btw, is a 1.0 w-reg, polo. thanks for help in advance
ps. is my car a 6n or 9n model?
Address 01: Engine Labels: None
Part No: 030 906 032 BC
Component: ME7.5.10 3174
Coding: 00031
Shop #: WSC 00000
VCID: 4C9C78B4564D
1 Fault Found:
16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
P0116 - 35-00 - -
Readiness: 0000 0100
Address 03: ABS Brakes Labels: 6X0-907-379.lbl
Part No: 6X0 907 379 B
Component: ABS 30 IE CAN V004
Coding: 05603
Shop #: WSC 00788
VCID: 438E53887B13
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 601
Component: 08 AIRBAG VW5 0003
Coding: 12344
Shop #: WSC 00788
VCID: F0E44C449A25
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 6N0-920-xxx-17.lbl
Part No: 6N0 920 904 D
Component: KOMBIINSTRUMENT BOO V06
Coding: 00441
Shop #: WSC 10001
VCID: 30640C44DAA5
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN
Coding: 00022
Shop #: WSC 00000
VCID: F0E44C449A25
Address 25: Immobilizer Labels: 6X0-953-257.lbl
Part No: 6X0 953 257
Component: IMMO 0004
Coding: 00001
Shop #: WSC 00000
VCID: FDFA6570DD77
help with my scanned faults please
polobear888
Reason: removed VIN number
Re: help with my scanned faults please
Your car is a 6n2
You need to replace the 4 pin green engine temperature sensor - get a new one from your local VW dealer. You must ensure its an original VW part as the copy parts are absolute crap quality
The airbag fault you can just clear. Nothing to worry about
- red6n2
Trust the man he saved my ass when vw tried to steer me wrong !.
polobear888
thanks alexperkins and red6n2, i dont think i will trust the garages, as they have took loads and loads of money of me, and still havent even fixed the fault, so my trust in this website, been to loads of forum before, and loads of people on there can be trusted. so thanks for your help guys.
do u guys know how much that part is? and what symptoms would i be getting if that part is faulty?
thanks in advance
thanks in advance
- red6n2
I changed mine like 2 3 Montserrat ago thanks to alexs advice my car was jerkin stuttering not viciously but enough to annoy I had a slight loss of power and when the engine was warm and I turned it off to then turn it on again it wouldn't start just kept cutting out till left for hours and the engine cooled then it would start again.
Vw tried claiming immobiliser issues which I knew was wrong else the car wouldn't start at all. But trust alex mate he has helped me out loads and never in the wrong direction.
Oh and it's about £30-£35 and remember to replace any lost coolant
its about £20 for the part i cant remember if it comes with a new seal and horse shoe clip, if not its best to get them too as they can be a little worn from the temperatures they recieve, and if you change it properly you wont loose any coolant but a bottle from vw is about £12 and always get the G12 from vw too where are you based? as im willing to lend a hand if your localish? im in lincoln
Theyve gone up a bit about £25ish now
They dont come with a seal or horseshoe clip, so ask for a new one when you get it.
polobear888
thats good then, seems like a cheap fix, thanks Bepe for ur help wanting to help me sort it out, but im in london, and that is many many miles for ya, so maybe i stick to a guide, unless someone else offers to help, but thanks for everyones help and advice, really appreciated.
- red6n2
im in northampton so closer but still an hour/40 min drive, its easy to replace but as bepe said replace the ruber ring and horseshoe clip, (actually im pretty sure mine came with a new ring but no clip wich i did eventually replace, any problem id happily talk you through it
polobear888
ive got this all sorted now guys, thanks for all the help guys
