Firstly you need to get hold of the clips that will enable you to pull the clocks out. You can always make it out of an old coat hanger like I did
(Note the sexy seat colours
Remove the radio and the block encasing it so you can get beside the clocks at the back
You then need to remove the crappy plastic cover around the steering column.
Take the screws from underneath the column first.
THen try and prise the top plastic bit off
This is probably the hardest bit of the hole thing, in that it's aquward. There is a small prong/clip going into the steering column which keeps it in place you may be able to get it off by just pulling the right way (which mine now does), but if it hasn't been off before it will be a bit harder and taking a screw driver to it is a good idea (after about 30mins you may feel like getting a sledge hammer at it but...
Once that's off, take the prong things. And put them in the clocks
At this point it easily come out, in the case that it doesn't get a screw drivers and push in the grey prongs whichare behind the radio on the left hand side of the clocks.
You'll then need to get the loom connector out of the back of your clocks, to do this you need to push the clip down and pull on the wire.
After that's out I HIGHLY recommend getting the casing for the lights out. A screw driver should easily prise it out.
Then you can undo the screws on the back... Done
