re-mapping my GTI?
re-mapping my GTI?
Surely you can't run 312mm callouses with a 280mm disc? The 312mm comes off the tt and other such cars?? Disc change isn't too hard just making sure that everything is bedding in correctly in order to stop dtv
Re: re-mapping my GTI?
benmkiv wrote:Surely you can't run 312mm callouses with a 280mm disc? The 312mm comes off the tt and other such cars?? Disc change isn't too hard just making sure that everything is bedding in correctly in order to stop dtv
I am still running standard brakes at 220hp n 300lbs/ft. If you don't brake late then they are fine
