H+R spring kit
NeilMcConville
Re: H+R spring kit
Post by NeilMcConville »
Thanks mate, hopefully will be getting a set soon :D
kevinctr
Drives: MY12 GTI 6R
Re: H+R spring kit
Post by kevinctr »
Eibach is another good choice!
1.4 GTI
Part Number: E10-85-024-02-22
Front -15mm/Rear -20mm
1.2 TSI
Part Number: E10-85-024-01-22
Front -25mm/ Rear -30mm
Front Anti-Roll Bar : E40-85-008-01-10 (22MM)
Der Finne.
Re: H+R spring kit
Post by Der Finne. »
kevinctr wrote:Eibach is another good choice!
You're quite right. Eibach manufacture the original VW aftermarket lowering springs for the 6R, they're just painted in a different colour and packed in a differently branded box. :)
I bought a set of both H&R 25/40 and Eibach 25/30 springs when I ordered my Polo, but after seeing several sample pictures decided to fit the H&Rs. The Eibach/VW kit leaves the rear of the car slightly too high IMO, whereas the H&R gives a perfect stance (again IMO, naturally). I measured the drop compared to my standard non-sport chassis, and in my case it was definitely the advertised 25/40mm if not a few mm more even.
The Eibach/VW kit is said to give a slightly softer ride than the H&R, though.
NeilMcConville
Re: H+R spring kit
Supposedly H&R are changing to details of the 25/40 springs to 20/35 as they dont drop enough...:L
Der Finne.
Re: H+R spring kit
NeilMcConville wrote:Supposedly H&R are changing to details of the 25/40 springs to 20/35 as they dont drop enough...:L
Might be, but my experience from the drop is quite the opposite! The amount of drop is naturally in relation to the weight of the car. Not all Polos weigh the same, so it is in fact fair from H&R to change the description to comply with the 'worst-case scenario'. That way no customer is misguided, and most will be pleasantly surprised to notice the drop was more than advertised...
Also worth considering that there are two different H&R 25/40 kits for the 6R available. Fitting a kit designed for the heavier front axle weight versions to a lighter-spec (literally) car naturally results in less drop. And vice versa.
H&R part no. 28977-1 for cars up to 929 kg front axle weight
H&R part no. 28977-2 for cars from 930 front axle weight
gavs
Re: H+R spring kit
Post by gavs »
Moreso that the spring manufacturer takes up some variation due to the high manufacturing tolerances set by the OE company. VW have issued a tolerance of +/-35 mm on the Amarok for instance so if you have a natuaraly, from the factory lower car (like i do), you will see less drop. The difference in weight of the car would be lucky to be 1-2kgs, max.
NeilMcConville
Re: H+R spring kit
Hopefully it doesnt drop too much cause i wont be able to get into my drive :L
SteveP
Re: H+R spring kit
Post by SteveP »
Looking to order some H&R springs next week, anyone know the cheapest place for them?
jeeks
Re: H+R spring kit
Post by jeeks »
I got mine from awesome gti in Manchester, got to me super quick too
Deako
Re: H+R spring kit
Post by Deako »
Do people go for the <929 or >930 kit on the GTI? Assume it would be the > 930 kit, with the increased weight on the GTI model.
jeeks
Re: H+R spring kit
Post by jeeks »
you'd want 930+ for the gti mate
NeilMcConville
Re: H+R spring kit
I ordered mine from orange tuning there this morning, was £115 for them and 20 quid postage. Should be here by friday :D
AJ_7
Re: H+R spring kit
Post by AJ_7 »
NeilMcConville wrote:I ordered mine from orange tuning there this morning, was £115 for them and 20 quid postage. Should be here by friday :D
Got them on yet mate?
NeilMcConville
Re: H+R spring kit
I do indeed, sitting in the boot at the minute. They might be getting fitted later, fingers crossed :)
SteveP
Re: H+R spring kit
Post by SteveP »
Mine shipped on Friday so should arrive on Monday :D
