handbrake light flashing
red6n2
Post by red6n2 »
ok so i can be driving like normal and all of a sudden my handbrake light will come on even though its not applied, but only for like a split second ive never had this problem before it started the other day, it was quite amusuing at first but now is just an annoyance, anyone know whats up ?
vagcom shows no sign of a problem,
rover220
Re: handbrake light flashing
Post by rover220 »
Low brake fluid.
red6n2
Post by red6n2 »
s**t... better get that seen to then eh :D
thanks mate,
pvr
Post by pvr »
If you have low brake fluid, there must be a reason:
- Either your pads have gone completely
- You have a leak
Simply topping up may not be enough.
rover220
Post by rover220 »
pvr wrote:If you have low brake fluid, there must be a reason:
- You have a leak
lol, not quite. dont scare the poor guy.
a leak is highly unlikely. top it up and go from there.
Jake_polo
Post by Jake_polo »
Does it beep briefly aswell? Mine does this from time to time along with the abs light usually find turning it off and on again does the ticket ahah ;)
i looked up flashing handbrake light in the manual when mine came on and it just says major brake fault do not drive your car. but they still work like a dream so ive just been ignoring it!
rover220
Post by rover220 »
Jake_polo wrote:Does it beep briefly aswell? Mine does this from time to time along with the abs light usually find turning it off and on again does the ticket ahah ;)
i wouldnt go posting stuff like that on an open forum where police and insurance companies can see, it might come back to haunt you.
pvr
Post by pvr »
- You have a leak
Where else would the fluid go? It is a closed system, the level only should go down when the pads wear and therefore the pistons are further out, causing the level of fluid to drop. When replacing the pads, they are back at maximum level.
If the level drops, I would certainly check my brakes to see if the hoses are leaking or if there is any evidence of wetness around the caliper.
rover220
Post by rover220 »
"the pads have gone completely".... unlikely to have gone all together more like worn within expectations.
check/top up fluid level and check brake pad thickness.
red6n2
Post by red6n2 »
im going round my mates later tonight to change my spark plugs, (hes a mechanic so il get him to take a look at it)
please jsut need topping up... i had to change insurance companys this month and had to pay 2 months upfront so money this month is non exsistant plus i had bills coming out my ass
pads should be ok but il get them looked at at the wweekend at the latest,
its only beeped once as its more of a split second flash rather than a prolonged on then off then on,
thanks, for all your help though guys,
red6n2
Post by red6n2 »
jesus christ i hope ther is no leak !!!!! :cry:
red6n2
Post by red6n2 »
right i can believe im such a novice with this but... can i just use universal fluid or does the 6n2 take a specific varient ?
mine a 1.4 8v ???
seriously i know loads about this car... this is just embarrasing :oops:
thinking my rear 'shoes' were replaced july just gone just before my m.o.t. and my front pads i think are a year old maybe slightly more,
rover220
Post by rover220 »
any universal dot 4 will be fine
red6n2
Post by red6n2 »
thanks mate,
red6n2
Post by red6n2 »
all topped up just below max, will keep an eye on it over the coming weeks but mate said it should be fine,
