Polo 6r GTI - Black
Re: Polo 6r GTI - Black
Lovely car mate, nice vid too!
what version of firmware do you have on the RNS-510?
- stuart.cameron
2760SteveP wrote:what version of firmware do you have on the RNS-510?
and maps are 7343(Navteq)
- stuart.cameron
Polo 6r GTI - Black
TMC now works. Turns out I just live in the sticks and not much happens round here. Went to Edinburgh today and it brought up a few things!
Bluetooth streaming is sill an issue...
My Bluetooth streaming music works Stuart
So no reason yours shouldn't unless there is some functionality in your phone to turn on?
- stuart.cameron
Polo 6r GTI - Black
Gonna have to have a look at VCDS later on and see what the problem is. What phone do you use? I'm using an iPhone 4 with iOS 5.0.1Hurdy wrote:My Bluetooth streaming music works StuartSo no reason yours shouldn't unless there is some functionality in your phone to turn on?
visionthing
Hi Stuart,
Just got my polo GTI last week and looking to install bluetooth and rns510. Did you install the bluetooth unit behind the heater unit or under the seat?.
- stuart.cameron
Do you have the climate controls or the manual controls?visionthing wrote:Hi Stuart,
I managed to fit the blueooth unit behind my climate controls with a bit of a squeeze. I don't know if i followed the guides correctly as I actually managed to remove the audio cage (Don't know if it was supposed to be removed or just moved enough to get the vents out)
Hi there,
I was wondering which version of the rns 510 u got? I was reading a bit of info online and some ppl have reported the unit draining the battery life... Just wondering if u have had any issues.... Im going to do same upgrade soon thanks!
Lovely car btw, any more plans on the works?
- stuart.cameron
The RNS 510 is version C (LED), if your fitting it to a new Polo I dont think there should be any battery drain issues. The battery issues are associated with the older VW's.lesgodoy wrote:Hi there,
Nothing planned yet, but you never know
Polo 2011 Moda
I have the RNS 510 C version in my Moda & when I checked my car the other day with a diagnostic machine, it mentioned to much power getting used from the CD system... Draining issue, my battery has never died but if I had it on with the engine off, it wouldnt take long for it to die.
- stuart.cameron
Bought a private plate today
- stuart.cameron
Not really done anything with my Polo since getting it except adding oil.
But did order some interior LED's yesterday. Should get them fitted tomorrow!
UPDATE:
Before/After
Before
After
UPDATE:
Before/After
Before
After
