Coilover Question (quick one)
Kieranyeh
Post by Kieranyeh »
Recently fitted my coilovers to my 6n2. Wound them all the way down front and back and the rear seems to go down a hell of a lot further than the front.
The reverse rake is unreal, so i wound them up a good 9 threads to sit flat.. Have i done something wrong up front?
I have a feeling i may have fitted the front ones wrong, i took the whole lot off the top of the standard coilovers and put it on top the new ones.
Its a cheapy set of TA Technix coilies that are on.
Is there anything i should have disregarded from the old suspension that i havent?
Is there any adjuster or anything i can remove to slam it down some more?
These are what they look like in the box
Kieranyeh
Re: Coilover Question (quick one)
Post by Kieranyeh »
Not much to go by but thats the level wound up about 9 threads at the rear to sit flat with the front
Bepe
Post by Bepe »
did you use the fatter springs that were included in the box as there for the 6n2 and the thinner profile springs are for the 6n
Kieranyeh
Post by Kieranyeh »
No i didnt :O
I had no idea, so i need the fat springs in these.. Don, cheers!
NotRich
Post by NotRich »
You're going to get pulled for those wheels. . . . .
6N2 GTI 00
Post by 6N2 GTI 00 »
Looks like your running F1 slicks :)
NotRich
Post by NotRich »
6N2 GTI 00 wrote:Looks like your running F1 slicks :)
So it does.
you're going to get pulled and get six points for those wheels.
Kieranyeh
Post by Kieranyeh »
They are sitting out of the arches, the centers dont locate to the bore, the tyres are racing slicks and they arent even nearly subtle about it
So yes 6 points if the officer feels like being nice, however i dont drive on those funnily enough aha..
