I have decided that its about time I cleaned my engine bay. Its covered in wax-oil. Can anyone tell me the best way (and quikest) of removing this?
MK 3 advice
MK 3 advice
Hi dubbers
hardhitter
- Moderator
IMO the best way is to do it by hand using engine degreaser and brush. It will probably take a few goes but it's worth the effort. It takes a while to get all the waxoil out.
I found that 'Gunk' isnt as good as some other degreasers out there. I prefered the comma engine degreaser as it worked better.
Karl_CLCoupe
- Platinum Member
ive just used some degreaser i bought from je-james for my mountain bike on the engine bay (it was about a cm thick in 13 year old oil and grease) put a little on a cloth and lightly rubbed it to test how good it was and to my suprise it fetched it straight off.
forgot actual make until i got home but i will edit and post it.
my engine bay is now shiny n clean....
There are a few really good products out there. It's all goign to depend on how much oil and grease and collected and where. Just be careful not to let degrease or detergents sit for too long. Some of these are pretty powerful and will soften rubbers and other soft seals.
Products that are worth taking a look at:
Gunk - The obvious choice for generally degreasing and cleaning up an engine bay.
Rock Oil's Soluable Organic Cleaner (SOC) - Available from most motorcycle dealers. Similar to Gunk, but far more potent.
Muck-Off - Originally designed for mountain bikes, but great for cleaning just about everything.
Have fun
G
Have fun
G
Gareth_GT_Hatch
- Platinum Member
You can use a steam cleaner as well. I used one on mine and it did the job pretty much striaght away. If youve got one with a brush attachment as well you can get to all the hard to reach places like beind all the brake pipes on the bulkhead ans stuff like that. Shame the brush is missing on mine tho, Ive only done the easy bits so far.
Karl_CLCoupe
- Platinum Member
Karl_CLCoupe
- Platinum Member
