Hi all am Frank from Malta, ordered a Black POlo 6R 1.2TSI 90
a question bou the interior intruments, seems over here these cars come only with the normal circle knobs for heater A/C settings but found that there can be a digital display instead of these, does anyone know what's involved in fitting a digital climate fascia rather then the typical round things? thanks
New member with a question
Re: New member with a question
The digital display would be for the 'Climatronic' AC, which is available as a factory built option. I do believe you can retrofit the actual unit, but you won't have the temperature sensors throughout the vehicle, they are only fitted if you select the Climatronic option.
Hope this helps,
Alex
Hope this helps,
Alex
Its alot of work an needs a new loom its just not cost effective
oh ok thanks a million
