Help needed, Clunking when braking
midgos
Post by midgos »
For a while on occasions i would hear a clunking sound coming my drivers side front wheel when braking. It has now developed into a louder sound that happens every time i brake. It sounds like metal hitting metal. Also i wobbled the wheel around just to check if it wasn't my wheel that was on loose, and i could rock the wheel back almost to the point were its hitting the arch. Does anyone know the possible cause of this problem?
Thanks in advance
Jake
quinnygti
Re: Help needed, Clunking when braking
Post by quinnygti »
Have you checked lower wishbone ball joints? Also check wish bone rear bush as thy often wear.
steveey
Post by steveey »
Will most likely be the rear wishbone bush mate, fairly easy job if you've got the tools. May be worth investing in a power flex kit for both sides as these are a weak spot on this car!
