Big Red - Wiper error *stuck on*
red6n2
Big Red [_space_]
Post by red6n2 »
Anyone got any clue why my electric mirrors don't heat up or move any more ?. The knob doesn't light up either :-/. The fuse hasn't gone as I checked that already ?.
Got me a bit stumped !.
M54 SINGH
Re: Big Red [_space_]
Post by M54 SINGH »
When you open your door, check the wiring inside that little rubber thingy in between the door and the body. In my old polo, some of the wires split somehow and i ended up buying a new window regulator because i didnt knw before. Just a thought :)
red6n2
Big Red [_space_]
Post by red6n2 »
A little something like...
Lol. Fixed that with a bridge and a straight through connector.
That resulted in my window working again after a year and a half... :mrgreen:
Anyway window still has a slight issue it seems it's off a runner or a runner has snapped as it will go down fine no problems at all but coming up its like it has uneven pressure and catches at the side furthest away from the wing mirror. And goes back down the passenger side does it as well. So il look into a fix for that when it's not freezing.
But as for the wing mirror issue it simply wasn't plugged into the back of the door card I must have forgot last time I took it off
M54 SINGH
Post by M54 SINGH »
lol thats exactly wt i meant... hope you get it all sorted soon dude.
red6n2
Big Red [_space_]
Post by red6n2 »
Thanks for the advise dude, very much appreciated !.
rafcoppa
Post by rafcoppa »
This is awesome. Mine had done exactly the same thing. There was me thinking Id have to buy a new regulator. Thanks very much!
M54 SINGH
Post by M54 SINGH »
red6n2 wrote:Thanks for the advise dude, very much appreciated !.
you're welcome buddy! :D
in regards to the window not cmin up, i think it may jus be the little plastic bit that clips into your regulator (which helps hold the glass has either snapped or come loose). Thats wt it sounds like based on wht you mentioned above. hope this helps....
red6n2
Big Red [_space_]
Post by red6n2 »
Ahh thanks, and there was me thinking I needed new regulators, il see if I can they can be replaced or if I can think of a fix when I take a good look at it will be ok till the weather warms up Though il just have to guide it up with my hand for now, defo need a new drivers side switch though i destroyed mine angrily when it stopped working.
red6n2
Big Red [_space_]
Post by red6n2 »
Was going to fit my GTI spoiler this month was going to tigerseal it on but has anyone used this stuff before ?. I don't know if I should wait till the weather is a bit better to let it set properly ?.
Any advice will help :-).
Trottagti
Post by Trottagti »
Yeah that will still set mate, still take a while but you will be ok, park it in the sun it will be fine...
red6n2
Big Red [_space_]
Post by red6n2 »
Sweet, il get on it as soon as !. I've had it well over a year it's time I just got on with it lol.
red6n2
Big Red [_space_]
Post by red6n2 »
Right so my plans for this year are sort of underway no massive changes but here goes
Fit the GTI spoiler (I've already started prepping this so shouldn't be too long)
New front bumper with GTI splitter (picking the splitter up tonight)
Smooth the front bumper, had a word with a mate and agreed a price
later in the year sort out the seats (still holding out for replacement red match seats)
Lower the front by an inch or so,
Perm fix the window cache,
And maybe spacers.
Done ski !.
M54 SINGH
Post by M54 SINGH »
sounds like a plan 8)
red6n2
Post by red6n2 »
right so i have got underway with finalizing my car...
heres the spoiler weve all seen them... not gonna go into depths with it,
im currently in the middle of getting whatever that black sticky crap around all the edge is off and then i shall be using tiger seal and bonding it to the car :)
ive aquired this...
so gonna learn to machine polish :D although i know these can ruin your paintwork very easily as its a circular motion one and not the figure of 8 kind so maybe will get a scrap bonnet or something and practice on that.
and todays purchase is this...
GTI splitter !
some slight scuffing from the previous owner
wont be fitted though until i have a smooth front bumper and it will be color coded so the scuffing isn't a problem as it will be sanded down
will also get my handles sprayed properly as the halfrauds red was tooo dark which is why i never fitted them then il be keyless
and some snow pics only taken on an iPhone
Trottagti
Re: Big Red shall i splitter in half :-)
Post by Trottagti »
You getting the bodyshop to do the handles and splotter at the same time?
And I would ditch the tow strap aswell, i had one and I liked it for a while but I think it is pretty naff now....
Once your splitter is on it will look mean..
